please help with spark plugs for high compression 347 build!
My buddy just bought a 01 ws6 with a forged 347 short block, ls6 heads and direct port nitrous. its 12.5:1 compression. so the plugs in the car when we bought it were for running on motor. they are NGK UR5. I assume its not a tr55 or tr6 because of the domed piston would hit something with that long of reach. so we need a part number for a plug that is 2 steps colder than stock, with the same reach of this UR5 but in a non projected tip. anyone know anything about NGK part numbers. or someone with a similar set up spraying with a big domed piston with short reach plugs. any help is appreciated.
Yes it should work , but, it isn't tapered seat. Should have washer. I would thread each plug in an old cylinder head first to seat it and crush the washer and then install them in the engine. Make sure and put some antiseize on the threads. I would gap them .026-.028.
Old thread and I'm pretty sure most of these people are long gone but as fuel goes there's MS109 which is unleaded and you have C12 and C16 which are even higher octane fuels but are leaded. They all cost more than E85 so what are the disadvantages of running E85? I get it with M1, it takes even more fuel injector and pump for it but if running high compression and adding boost then it would be my go to fuel.
