What the hell could have caused this???
Once again, valve float. You better check those springs b4 it happens again.
In regards to being asked about when to change springs; call your spring supplier or manufacturer for confirmation.
LS1Tech Sponsor
Maybe floated the valve and it hit the piston snapping the head off?
__________________
Don't forget to check out our products at www.saccitycorvette.com
![](https://ls1tech.com/forums/signaturepics/sigpic197936_1.gif)
If you like our products, tell others! If not, tell us!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
In his sig, it states LS3 heads. Most people won't run aggressive ramps/lobes with solid(L92) valves. Having a HD-SS valve that might poss. be even heavier isn't a good thing. I'd contact who set up the heads/spec'd the cam.
I hate that you had the problems with the set up, Let us know if we can help you with something to get you on the road again. We have our TMS Stainless valves and great high boost short blocks all with a 1 year warranty to help with the concern of having this not happen to you again. Give us a call and we can get you on the road in no time.
#33
A guy in Texas did the work to the heads and he's going to help get it fixed. I just have to pay to get the actual head fixed hes getting me a new rod and piston. Also I don't think it was valve float or a ptv clearance problem because there isn't any other marks on the other pistons at all. And I called Thompson on a short block or boost you guys had on here I'm going to fixed this engine all up and then sale it and do a turbo build.
#40
