Piston ring gap on a 383
Old Jun 14, 2013 | 11:45 PM
  #41
JakeFusion's Avatar
Super Hulk Smash
What in the flying ****.
In other news that Wiseco chart is awesome.
Old Jun 15, 2013 | 02:32 AM
  #42
ckpitt55's Avatar
Old Jun 15, 2013 | 06:00 AM
  #43
RezinTexas's Avatar
Back on topic...
Originally Posted by rayman3550
Great now I need to find a file fit machine and redo all of them
Just buy one and do it yourself, its super easy.
http://www.jegs.com/i/Proform/778/66785/10002/-1
In that case what would happened if I decided to throw a 150 shot of nitrous? Or even more?
If you're running nitrous, then you need larger ring gaps.
Here is the link you need for Mahle pistons, see page 17. The 2nd ring gap needs to be larger than the first.
http://www.mahle-aftermarket.com/C125790900540AC0/vwContentByUNID/473F7966C5605DEEC12579AB006096B9/$FILE/PR-40-10.pdf
Also, I see that Manley specifies a larger top ring gap (vs 2nd ring). That is contrary to every other source I have seen for piston rings. This may be one of the sources that is continuing to fuel the uncertainty in the engine building world...
http://www.manleyperformance.com/dl/...ston-rings.pdf
Old Jun 15, 2013 | 06:01 AM
  #44
PREDATOR-Z's Avatar
Originally Posted by ckpitt55
It is in 3D as well
