LS3 Small Bores- What cam?
What is your cam? I agree, if you're only gaining 8 hp with a fast you have a restriction somewhere. Either the heads or the cam.
FYI, my old setup was very mild...
AI 226cc 799 heads 60cc chambers
AI 226/230 Cam
Kooks 1 7/8" catless
This combo put down 435 with an ls6 intake
Added a fast and LS2 tb and it went all the way to 462 on the same dyno.
AI 226/230 Cam
My setup is:
PRC 2.5 LS6's stock 64cc chambers
LS2 TB
Fast 92
230/230 Pat G cam
ARH 1 3/4 catted - just added yesterday
Put down 431.
Cam is not your issue for sure, that is a good cam, although a cam with some more overlap should make more power.
This is how I would proceed if I was in your shoes and it should be fairly cheap if you do your own labor.
1) Pull heads
2) Flycut pistons
3) Mill heads to 58CCs and get a cometic .040". You could also sell those heads and get AI 243s, which I think are better heads overall. They never DON't make power on the setups I have seen them on.
4) Put in a bigger stick (optional as I still say that cam is good for up to 460 rwhp in your setup)
Could also just be a stingy dyno, but compression gains a lot of power in these cars.
I think if I change sticks, I'd at least change heads and most likely just add cubes. More cubes will get me to the power I'd like using LS3's.
1) Pull heads
2) Flycut pistons
You seem to just want to try something different, there is nothing wrong with that.
You can recoup a lot from selling your heads and fast, you could almost make it an even swap going to the new small bore heads and finding an ls3 intake with rails and injectors. I found mine for $350 shipped. You'd just need the adapters for the pig tails, FIC sells them. You can get $550-600 easily for the FAST and probably $800-1000 for your heads (I am guestimating here, I got $1000 for my AI 243s. The small bore heads are only $1400 after adding the offset rockers arms and pedestals.
I vote for doing that and using an ls3 friendly cam, like the 230/234 or the 230/238 like I am doing.
Then if it doesn't work out, you have a nice solid top end for going LS2 stroker or boost!
If you go that route, definitely mill the heads .030, use the cometics, and flycut your pistons or you will regret it. Unmilled the compression is too low for an ls1 IMO.
Good luck. I will keep you posted if I get any dyno numbers or track times.
Not sure how to determine how shrouded the valves are. All I know is that it is similar to regular LS3 valves on an ls2 bore since these valves are 2.08" on the intake and the stock ls3s are 2.16". Ls2 bore is 4" my bores are 3.908, so the ratio valve/bore size is very similar. Another plus is that these use nice ferrea valves which are very strong, which is nice for big horsepower later down the line ( boost, nitrous, etc)
The only reason I am running the manifolds now is because when the **** hit the fan, I quickly sold all my mods and LS7 manifolds are cheap. They actually make great power on 347 cube cars, very similar to headers. The LS7 guys only pick up 5-10 rwhp with headers on the stock cam. GM did a great job on these manifolds. Theyre on the ZR1 too.
I am actually going with just a run of the mill a&a kit. A 230/238 cam wouldn't work well with a turbo.
Probably v3 so I dont have to drill a line
No headers, no need for them.
Yes, cam is on a 115 to keep the overlap at 4.
Some guy on vette forum is making 700 through these manifolds...even through the cats. He swapped his headers for them and only lost 15 rwhp.
I gutted the cats on mine.
Since you're looking at aftermarket options with smaller intake valves and higher exhaust flow, you could probably get by with a slightly larger cam. Reversion becomes less of an issue. You could do something like a 234/242 114+2 and still be ok (especially if you go 383 - you want a later IVC with a 4" stroke) or 114+4 on the 346.
I am now putting in an Ed Curtis cam, which has very low duration on the intake side and a wide split to the exhaust side. Going right to the track.
I was only hitting 12.4 @ 119 with the 231/239 cam...it was VERY lazy in the 1/8th. Could only trap about 91, so picking up a huge 28 mph on the back half. Hopefully the new cam will fix the 1/8th mile portion and I can dip into the bottom 12's at over 120. I'd be happy with that considering it's still on manifolds.
I also think the manifolds are hurting you pretty badly. As one very knowledgeable cylinder head guy stated, on these lower RPM street engines overlap is where there is really the most inertia in getting air moving through the engine and thus getting that delicate balance between clearing the residual exhaust gases and scavenging the intake without it all going out the exhaust will pay big dividends. OEM manifolds certainly don't help with this.
Well, they're LS7 manifolds connected to a full 3" exhaust all the way to the bumper. Pretty nice pieces, not like I am running on the crappy ls1 manifolds. I am sure I am giving up .2 et and 2 mph or so, but nothing more than that. Mostly torque in the mid range probably.
But that is why I went to Ed, he specced me a cam specifically for my application knowing I had the LS7 manifolds.
If huron speed ever puts back the C5 xspower headers, I will hop on them. Sorry though, not paying $1600-1700 for American catted headers and no way I am going back to catless Kooks like I had before. The Kooks cat pipe alone was more than I spent on my manifold, cats, and 3" crossover pipe setup. I just couldn't take the catless + cam smell anymore. Tired of going into the office smelling like it.
Ed really wants me in the Mast SB LS3's, and I have a quirky trick up my sleeve next year if I get them. But I believe he truly knows what to grind to actually take advantage of the heads. I'm glad you made this thread, bc I was just about to start my own. I think aside from a cam swap, I've taken my heads about as far as I can.
OP, hope you don't mind me piggybacking in here. There really isn't a lot of info available on these, other than the magazine test.
Picked up some LS7 heads and the intake for a good number, now I'll need to send them off for new SS exhaust valves and porting!
I think it's going to be neat to see some folks run the small bores. They may be lazy down low, but as I've hearth said many times, who races below 4k? The LS3's should freight train at high Revs!
