How long does a head swap take?
Old Apr 27, 2004 | 09:32 AM
mean02's Avatar
Default How long does a head swap take?
I've installed cam/valve springs on a car in about 8 hours. I've done about 6 of these installls....But, I've never done a head swap. How long does it take?
Old Apr 27, 2004 | 09:42 AM
Scalpel's Avatar
About 4 hours at the most, IMO.
Old Apr 27, 2004 | 09:44 AM
jmX's Avatar
jmX
3-12 hours
Old Apr 27, 2004 | 09:46 AM
OWENMUSTANG's Avatar
IF this is your 1st, double that then you should have extra time for whatever happens
Old Apr 27, 2004 | 09:51 AM
foff667's Avatar
LS1TECH Sponsor
i found the hardest part was taking out the head bolts & cleaning all the holes...by yourself this part can take 2-4 hrs by itself let me tell ya I was tired lol My air tools couldnt handle taking the bolts out so it was all done by hand. Other than that its pretty easy and straitfoward...could be a bitch if the car has headers...some have issues with getting the headers to drop down far enough especially if they are welded up at the collectors to the rest of the exhaust...even if they are not U style clamps tend to crimp the tubing and make it very difficult to separate them. Those are the pitfalls i came across though most i had no problems with just throwing out what ive heard & seen secondhand
Old Apr 27, 2004 | 10:00 AM
gomer's Avatar
I have head studs on my car now and I've had some practice ... so I can ususally do it in 2 or 3 hours with one helper. For a first timer and having to clean the bolt holes.. I'd say 6 to 8.. maybe longer.
Old Apr 27, 2004 | 11:56 AM
TRYMYZ's Avatar
I have done it a total of 6 times on LS1s and I would say 4-6 hours. I am meticulous about scaping the block and cleaning the bolt holes. If your like me then it will probably never take loner than that.
Old Apr 27, 2004 | 12:17 PM
v8maro's Avatar
It took me and my bud 16 working hours to do heads and cam. We spanned it over 2 days. He had done cam swaps before, and neither of us had done heads before. I'd say you could do it in 12-14 if you really want to push it.
-Steve
 Michael S. Palmer
Old Apr 27, 2004 | 12:41 PM
Tech's Avatar
Took one evening 3-4 hours to remove it and another 4-5 to install it the next day. It was the first time I've done a cylinder head. I'm sure I could do it a little faster but if I'm going to pull the heads, I'm not going to rush. Give yourself 2 days.
BTW, this is ONE head with no air tools and stock manifolds.
Old Apr 27, 2004 | 12:49 PM
robertbartsch's Avatar
I've done several head swaps but only one Gen 3.
I did the LS1 at home in a weekend with no air tools...
...the amount of time you will spend depends upon what your doing; one time consuming task is changing the oil pump and timing chain sprockets and cleaning out the bolt holes in the short block....also cleaning the deck takes a bunch of time. The header bolts and exhaust can be combersome too. pulling and re-installing the radiator is a pain.... and on and on and on and on...
...make sure the piston tops (scrap carbon off) and piston holes are spit clean (use paper towels and brake cleaner or silicone spray), the bolt holes are dry and clean - see JMX's web page for a very detailed instructions - very useful for even experienced wrenchers...
Suggestion: don't rush anything or you will be doing this twice.
...good luck and enjoy the knuckle busting wrench turning experience...
Old Apr 27, 2004 | 01:01 PM
Zanthius's Avatar
I helped my buddy do it in a weekend last year. Occassional bullshit sessions included it took 2 full days...
Old Apr 27, 2004 | 01:06 PM
mean02's Avatar
Thanks for all the reply's! I'm leaving the cam I have in there for a while. I remember the dip stick tube for the trans. is bolted to the head on the pass. side....will I be able to get that from the top after the intake is removed? I can't wait to get the car done.
Old Apr 28, 2004 | 04:47 PM
mean02's Avatar
Anyone know about the dipstick tube thing?
Old Apr 28, 2004 | 08:26 PM
Jabroni's Avatar
Yes, you can get the dipstick but it's easier after the coil packs and wires are out of the way. FWIW, it took a buddy and I 6.5-7 hours and that was the second one we did. We stopped for lunch for 45 minutes and took our time using air tools for about half the job. It was much easier than the cam swap alone...trust me.
