Advice?
Old Jun 13, 2013 | 02:16 PM
jbrockwell's Avatar
Default Advice?
So in the next few weeks I'm going to be doing a cam/springs swap. Its an 01 SS with all boltons, and I'm in the process of selecting each part. It's my dd and I will be tuning it. That said, I know I want a lower LSA and a maximum duration of 224.
I'm leaning towards a TSP 224 .581/.581.
I'm new to spring changes and the ones I'm looking at are these -->
http://www.ws6project.com/user_stor/...0d87bb84d73ad8
Since I'm installing them while the engine is still in the car, would using dual springs make it any more difficult than just single springs?
And if anyone things there's a better cam for my use suggest away.
Old Jun 13, 2013 | 02:25 PM
PREDATOR-Z's Avatar
Are you M6 or A4?
What rpm powerband would you desire?
Old Jun 13, 2013 | 02:44 PM
BIG_MIKE2005's Avatar
I absolutely love my 224/.581 cam but I also have a LS6 intake, port/polished TB & worked over 5.3 heads too. Only way I'd change my cam would be if I got a EPS custom grind to match the rest of my current combo though. This little 224 has surprised quite a few people.
Old Jun 13, 2013 | 03:05 PM
wildcamaro's Avatar
Single or dual springs has no bearing on installation difficulty...good choice for a daily driver cam, I have a 224/230 with same lift and I have no gripes on dd it...just make sure you pull the radiator and condenser, it will make life easier when doing cam
Old Jun 16, 2013 | 01:21 PM
jbrockwell's Avatar
Originally Posted by PREDATOR-Z
Are you M6 or A4?
Its an m6
I also have ported tb and lt's
And i plan on removing the radiator and condensor
Thanks for input guys
Old Jun 16, 2013 | 02:44 PM
PREDATOR-Z's Avatar
I would go 224/224 .581/.581 110+0 LSA (110 ICL)
Old Jun 21, 2013 | 08:25 PM
jbrockwell's Avatar
What do you guys think about swapping rods? Is it necessary for my cam choice and would it be do-able without pulling the motor?
Old Jun 21, 2013 | 08:41 PM
alexus6798's Avatar
Only rods that need to be swapped are your pushrods..
Old Jun 21, 2013 | 08:47 PM
oakley6575's Avatar
No reason to swap rods.. I would go with what PredZ said above. And up the compression if you can. It will be a whole new animal
