Which heads for hot cam
Old Jun 16, 2013 | 10:14 AM
02fbody35th's Avatar
Default Which heads for hot cam
So I'm looking for a set of heads for my ss. Right now I have the gmpp hot cam with supporting mods and I'm very happy with this cam. I'm just looking for a good head. The two I was considering are texas speeds 2.5 ls6 head or the 2.5 5.3 head. Which would you guys recommend? And at what cc chamber should I mill to? Any thoughts or experiences would be appreciated
Old Jun 16, 2013 | 11:24 AM
badamn's Avatar
Default jjhj
i was going with a similar setup,i think people ended up recommending the 5.3s because u get a little more hp with the higher compression.
Old Jun 16, 2013 | 11:50 AM
Tan327's Avatar
I look at it this way, if you're happy with the hot cam, then you'll most likely be happy with any CNC'd head on the market. It doesn't sound like you're going for a maximum potential build so I'd save money by going with the TSP 5.3's and call it a day. Good deals can be had in the for sale section on these once a week or so.
Old Jun 16, 2013 | 01:01 PM
Yep, u said it right. I'm not looking for every hp I can get. That being said. You feel the 5.3's will out perform the ls6 heads with my cam? Any thoughts on chamber volume I should shoot for?
Old Jun 16, 2013 | 01:26 PM
Tan327's Avatar
TSP has said that both of those heads usually dyno within 5 hp of each other, so really it's your call. I'd prefer LS6's if I were buying for my setup, just because of the resale value and room to grow. If I was in your position I'd save the $2-300(I believe) and pick up the 5.3's, or just throw on a stock/ported set of $4-500 243's and gain 20~30hp.
I'd go 2.5 5.3's and talk to TSP about milling for 59cc, stock GM gaskets.
Old Jun 16, 2013 | 01:28 PM
Sounds good. Thanks for your advice!
Old Jun 16, 2013 | 01:29 PM
So anyone have any numbers or expierence to share with the hot cam and a set of heads?
Old Jun 16, 2013 | 01:58 PM
MikeWS6's Avatar
I gained 48whp/21 tq with the tsp prc 5.3s.
Old Jun 16, 2013 | 02:09 PM
Very nice!
Old Jun 16, 2013 | 05:07 PM
garygnu's Avatar
can you get the TSP port 5.3 head with stock GM springs ?TSP ported stage 1 ls6 heads come with stock GM springs .
Old Jun 16, 2013 | 05:18 PM
I don't think so. But I would just order them without springs and reuse my ls6 springs
Old Jun 16, 2013 | 10:38 PM
MikeWS6's Avatar
Very nice!
Cam only to tsp prc 2.5 5.3 heads (graph)
Old Jun 17, 2013 | 09:04 AM
I like what I see! Very nice gains across the board
Old Jun 17, 2013 | 10:28 AM
BigBirdLS1's Avatar
I gained 38rwhp and 30rwtq over cam only by adding TSP 2.5 5.3 heads. I changed nothing else at all either. IMO they are the best budget stock casting $ can buy. I've always seen good results with these heads.
