What is the most HP i can get from an LS1 engine w/o going forced induction?
Old 06-17-2013, 09:51 PM
lemons12's Avatar
Originally Posted by badazz81z28
I'm at 450 to the wheels now. I have the 228R cam. I'm pretty much maxed out N/A with the exception of the cam and porting my FAST. I find it hard to believe any cam added to my combo is going to gain 50hp to the tires. I guess environmental condition can gain a few ponies too...if you have to spin the engine to 7200rpms...Its got to suck down low.
What heads and exhaust? I bet you aren't anywhere close to maxed out even with the current cam.
Old 06-17-2013, 09:53 PM
badazz81z28's Avatar
I have the PRC LS6 Stg II heads, 1-7/8 LTs with true dual 2.5" with dynomax Ultra flow mufflers. FAST 102 intake/FAST 92 TB / 85MM MAF/CAI/36lb injectors.
Old 06-17-2013, 09:59 PM
"MAC"'s Avatar
Read up W2W and see what they did they pretty much have step by step on how to make a 500rwhp+ car and you will learn a lot or you can try and take the lazy way and ask people on here how to do it like i try and do lol.
Old 06-17-2013, 10:01 PM
"MAC"'s Avatar
IS the MAF really needed at all? My tunner tuned it to where I didn't need it. Just wondering if the MAF helps it run better or not. I haven't had any problems what so ever when he tuned the MAF out as well.
Old 06-17-2013, 10:18 PM
I would imagine the engine would need some form of reference as to how much air is coming in, but I have no idea.
Old 06-17-2013, 10:41 PM
lemons12's Avatar
Heads are definitely lacking... A set of AFR/TFS heads would be much better.
3" on the true duals... I'm not familiar with ultra flows so I don't know if there is power there.
Port the intake.. Add a 102 TB.
SD tune
There is power left in 98% of setups.
Old 06-17-2013, 10:50 PM
lemons12's Avatar
Honestly.. I'd rather do a crap top end 408 before pour tons of money into a 346.
It would make roughly the same power with **** tons of torque... Biggest difference... One is fully forged and 408 CI.. And one isn't and is 346 CI.
Old 06-17-2013, 11:02 PM
Always2Slow's Avatar
Couldn't agree more lemons. I see so many people throw tons of money at small cube setups like a bad habit and ask them what are your goals and what are you doing with the car. Unless your going to break the SBE record why not have a bigger broader torque curve, which matters more on the street than a peaky 346 that cost alot of money.
Old 06-18-2013, 01:03 AM
Super Hulk Smash
JakeFusion's Avatar
Or you run a combo that'll port over to a 402 pretty easily and still keep making power. Just swap the cam (in my case, that's what I plan to do).
Here is a recipe for 500rwhp: https://ls1tech.com/forums/generatio...heads-cam.html
Old 06-18-2013, 01:07 AM
lemons12's Avatar
It isn't a bad idea..
I'd rather the stroker now though. LOL I'm impatient.
Old 06-18-2013, 01:09 AM
Super Hulk Smash
JakeFusion's Avatar
To do a stroker right, you need to spend money on it as well. Putting Pacesetters, LS6 intake, and whatever heads on there... you see a lot of folks sink pretty decent money into a forged shortblock, run out of cash, and buy a pretty awful topend. Their power isn't any better than a well-sorted heads/cam... neither is their torque.
Old 06-18-2013, 01:14 AM
  #32
lemons12's Avatar
The guy that did my 408 put..
stock fast 90
pacesetter 1 3/4 with a horrible merge and a catback no cutout
patriot 243s... flows 302 cfm
Still was dead even with my 370... 370 was roughly around 455Rwhp/415Rwtq and weighed around 200# less when they ran.
It has also been dead even with a 455Rwhp C5Zo6.
I just installed a 102.. Then I'm doing TFS 235s and 1 7/8 and fixing the merge/adding a cutout.
I'd take a mismatched/cheap top end stroker to a nice 346 any day.
Old 06-18-2013, 07:03 AM
  #33
Freefallin's Avatar
Ok...this is what i understand so far...it IS possible to get 500rwhp from a stock cube LS1 BUT it is going to be challenging and cost a fortune.
You could get way more than 500rwhp by changing the block to something like (as LS6427 said) an LS2 block resleeved to 454. This would also cost you way less.
Is the above conclusion correct?
Old 06-18-2013, 07:45 AM
  #34
PREDATOR-Z's Avatar
Partly.
Bigger cubes cost $$ as well. They just dish out more and possibly more reliably. 427s or 454s need big heads. LS3/L92 are decent but LS7s are better. Then you have to consider drivetrain etc...
Old 06-18-2013, 07:50 AM
  #35
ramairetransam's Avatar
475 ish to 500 , your gonna need all the stuff, awesome heads, huge cam, large lid, larger maf , fast 102 and rails and tb .
Old 06-18-2013, 08:56 AM
  #36
Super Hulk Smash
JakeFusion's Avatar
LQ4/9 block is the cheapest way to get big cubes. Anything else is going to really add up... LS3 or LS7 blocks cost a lot. Resleeved LS2s cost even more.
Old 06-18-2013, 09:00 AM
  #37
Super Hulk Smash
JakeFusion's Avatar
stock fast 90
You just proved my point. The 408 wasn't walking anything despite being a 408. You might have had less money in it compared to the other setups, but that's doubtful as well - compared to a forged 370, it probably wasn't much more expensive, but compared to a stock 346, there is no money in that.
Point is, power and speed cost money. Cutting corners only forces you to buy things more than once, which in the long run, ends up costing a lot more than doing it once and doing it right.
To the OP - buy things that can be portable to a new setup. Buy good heads, not cheap heads that you need to replace later. Buy a good exhaust setup, good intake manifold, etc. Things that will make a 346 shine will also make a 408+ shine as well.
Old 06-18-2013, 10:13 AM
  #38
LS1-450's Avatar
LOL, Pat G posted a complete thread from start to finish on what he did to achieve streetable 500+ RWHP. Engine is only part of it. IDK if he's still on here or maybe the thread trickled off. Seems the archives aren't a deep as they used to be.
He did things like lightweight flywheel, hollow stem valves, head port, intake port, windage, exhaust mods, pulley, TB, degreed cam designed to his grind, high RPM (tune & injectors...obviously) Don't remember if he used a vacuum pump to get negative crank case pressure or not. Pushrods, rockers, lifters etc..
Old 06-18-2013, 10:17 AM
  #39
MikeWS6's Avatar
If this is going to be a street car, power under the curve is where its at. I wouldnt worry as much about peak numbers.
Old 06-18-2013, 10:50 AM
  #40
Super Hulk Smash
JakeFusion's Avatar
See post #30 above.
Quick Reply: What is the most HP i can get from an LS1 engine w/o going forced induction?
