looking for good spec on turbo cam???
Old Jun 21, 2013 | 09:27 PM
rorric's Avatar
Default looking for good spec on turbo cam???
Ok guy I have a 370 with ls3 top end.. looking for a turbo cam this is what's in it now I was told its a small cam 215/223 604/610 115 lsr I plan on doing a 78 mm front mount turbo it will be a street strip car .. what do you guys think should I keep it or is there more power to be made with a different cam if so what's your specs? Thanks
Old Jun 23, 2013 | 11:30 AM
mark21742's Avatar
That is a small cam for a 370.....I'd look for something closer to a 228-230/234-236 your lift sounds good and your lsa sounds good, I'd just like to see more duration
Old Jun 23, 2013 | 11:45 AM
leeluther252's Avatar
Dependent on your goals of course, but a few extra horses from a different cam probably wont be worth it knowing you will be making most of your power from boost.
227/235 .614/.621 114 LSL lobes.
*edited a complete typo*
Old Jun 23, 2013 | 04:33 PM
mark21742's Avatar
But then again n/a HP increase from a cam swap can be amplified greatly by the additional of boost
Old Jun 23, 2013 | 07:40 PM
Camaro9969's Avatar
Pm Martin from tick he will point you in the right direction
Old Jun 23, 2013 | 07:46 PM
PREDATOR-Z's Avatar
Keep the one you have it is fine.
Old Jun 23, 2013 | 07:52 PM
oakley6575's Avatar
There are a lot of 1000rwhp turbo cars/trucks that use cams smaller than the one you have. I would contact Jarrett (stock48) on here and see what he thinks. He has proven time and time again to have some of the best turbo cams out there.
Old Jun 25, 2013 | 07:43 PM
Sales@Tick's Avatar
229/235 .615/.621 116+2 LSL lobes.
Why on God's green earth would you close the intake valve that late with a port that has the cross section of a ls3 head not to mention the gigantic intake valve it also has.
