whining noise from engine
Old Jun 23, 2013 | 10:57 AM
GHall8788's Avatar
Exclamation whining noise from engine
Today I was hitting the gas hard and did a spin, right after I had a whining noise coming from my engine. it gets louder/higher pitch as I accelerate. Does anyone know what this is?
Old Jun 23, 2013 | 11:26 AM
mark21742's Avatar
If you still have power steering, check to see if the noise is coming from your power steering pump....check its fluid level and if its low be sure you put the right fluid in it (some of our pumps will be destroyed if you put power steering fluid in them if they call for ATF)
Old Jun 23, 2013 | 11:44 AM
GHall8788's Avatar
I cant tell if it is, my exhaust is so loud. I can only here it from inside the car.
Old Jun 23, 2013 | 12:24 PM
crainholio's Avatar
Pull your power steering cap/dipstick while the engine's idling, if there are bubbles in the fluid that's your whining noise. A few slow turns of the steering wheel lock to lock should purge the air.
