G5X2 and Auto?
Old Apr 27, 2004 | 09:20 PM
BoneSS's Avatar
Default G5X2 and Auto?
How big of a stall would be needed? At least a 3600-3800? How about gears? 3:73? Search did not yield very much info, so I thought I would check present opinions...
Old Apr 28, 2004 | 04:44 AM
BoneSS's Avatar
Anyone?
Old Apr 28, 2004 | 04:57 PM
Dmoney's Avatar
I have a TCS 4200. Not too bad. It's loose but you'll love it at WOT. I put down 410 & 380 and I only lost 7 rwhp when I changed from a Vig 3600 to the TCS and I have 3.73's also. It still surges a little( need more tuning) but it feels awesome.
Old Apr 28, 2004 | 09:13 PM
mike c.'s Avatar
DMONEY. i just ordered the x2 cam 112lob(m6) does that cam shake the car real bad when idling? i will be getting it tuned.
Old Apr 28, 2004 | 11:24 PM
mikemodano9c's Avatar
BoneSS...get around ~3500 stall or higher...
A good n/a stall would probably be around a 4000 or so...
Old Apr 29, 2004 | 05:54 AM
BoneSS's Avatar
Thanks Mike. My Vig flashes around 3200-3400, so I thought that would be a little low for that cam.
Old Apr 29, 2004 | 07:21 PM
Dmoney's Avatar
Car idles fine, no shaking whatsoever, but the sound is very noticeable.
Old Apr 29, 2004 | 08:53 PM
BoneSS's Avatar
I still think it might be a little too big for what I have now. Would 373's help out?
Old Apr 29, 2004 | 10:42 PM
g5x2's make good low end torque for being a decent size cam...i would install the cam, get it tuned, and then go run some times...look at your 60ft and slip and then determine if you want to get a bigger stall...
Old Apr 29, 2004 | 10:52 PM
01_SuperSlow's Avatar
Car doesn't shake with the X2. Only the engine and shifter (if manual) will shake at idle .
Old Apr 29, 2004 | 11:44 PM
Z-Rated's Avatar
would 3.42s suffice with a huge stall, ie 4000?
