PSI 1511 or PAC 1211x
Old Jun 29, 2013 | 07:24 AM
redbird555's Avatar
Default PSI 1511 or PAC 1211x
Hey guys I posted this in another thread but didn't get much feedback. My cam specs are....
Eps 222/234
.604"/.604"
115+3
So it's kind of a sleep cam with a larger duration and lift. I want to run a beehive for the weight and valve control. I think I should be fine with either the pac or psi spring as they are both rated to .625 lift. The pac springs though are quite a bit cheaper so I was just seeing if anyone had a preference one way or another. I know pac makes a good spring but I just have never seen the 1211x used so I'm a little skeptical about trusting a motor with it
Old Jun 29, 2013 | 07:54 AM
PREDATOR-Z's Avatar
I've used both, PSI would be my choice $$ allowing.
Old Jun 29, 2013 | 09:40 AM
JakeFusion's Avatar
Super Hulk Smash
I'd do the PAC 1519 with EPS lobes. 150lbs seat pressure will be your friend and so will a nitrided ovate wire.
Old Jun 30, 2013 | 11:14 AM
*02WS6TURK*'s Avatar
PAC 1518's here with my EPS 226/234 cam. Great springs.
Old Jun 30, 2013 | 11:33 AM
RQSGTO's Avatar
PSI 1511's here with a 220/224 .600/.600 111 cam, stock retainers and locks on stock LS6 heads.
Great springs!
