What cam?
Old Jul 3, 2013 | 08:09 PM
Atdc94's Avatar
Default What cam?
ok I know, do a search. But I have and I really can't find what I am looking for. I want to cam my 2000 z28. No major mods. Just the basic bolt ons. I want a cam that that sounds mean at idle and gives me more low to mid range power. I really don't know too much about cams. Thanks for the input.
Old Jul 3, 2013 | 08:20 PM
Always2Slow's Avatar
227 lsl lobe 234 lxl lobe on a 110 lsa installed on a 110 ICL.
Old Jul 4, 2013 | 12:22 AM
JakeFusion's Avatar
Super Hulk Smash
Either of these would be good:
http://www.tickperformance.com/tick-...1-ls6-engines/
http://www.briantooleyracing.com/nat...-camshaft.html
Each has a smaller 223 cam, but I think you'll be fine with either of the 227 cams. The Tick cam will make a little more power and torque, but will be a little more rowdy on the street. The BTR cam will drive a little nicer and still make good power, but not quite as much torque.
Old Jul 4, 2013 | 07:59 AM
Atdc94's Avatar
What do you mean by rowdy? lol
Old Jul 4, 2013 | 11:35 PM
Qfly's Avatar
Tick Performance SNS Stage 2 with the mild lobe..
Give Tick a call and tell them what you are looking for and they will hook you up.
Q
Old Jul 4, 2013 | 11:36 PM
anheuserbusch08's Avatar
Torquer v2 and ull be set
Old Jul 5, 2013 | 12:30 AM
Detoxx03's Avatar
Futral F11 has a nice broad powerband.
Old Jul 5, 2013 | 10:47 AM
JakeFusion's Avatar
Super Hulk Smash
It has more overlap. So it will make more power, but also will idle a little worse and cruise a little worse in comparison.
However, with a good tune, it shouldn't make much difference. The overlap isn't so great that it'll be awful with a good tune.
Old Jul 5, 2013 | 06:27 PM
Atdc94's Avatar
I think I want it more rowdy haha
Old Jul 6, 2013 | 06:48 PM
garygnu's Avatar
make power not sound .the correct exhaust and tune can achieve the sound you want .a cam with a narrow lsa will give you a choppy sound.talk to cam tech to get the best cam for your whole car combo.
Old Jul 7, 2013 | 04:05 PM
Sales@Tick's Avatar
I think you'd really like the SNS Stage 2. Here are a few idle clips of it:
Old Jul 7, 2013 | 09:54 PM
Atdc94's Avatar
Hey Martin. Yeah I was actually looking at that cam on yalls website. Do yall sell the kits with springs and everything or would I buy those separate? Thanks for the help
Old Jul 9, 2013 | 07:39 AM
Sales@Tick's Avatar
If you're looking for low to mid range power, and a choppy idle then you have found the cam you're looking for.
Yes we do sell an entire camshaft swap kit for $929.96. That includes an Elite Series Camshaft of your choice, Brian Tooley Racing Platinum Springs with tool steel retainers, Comp Cams Magnum push rods in the length you need between 7.300"-7.500", LS2 timing chain, balancer bolt, 2x water pump gaskets, timing cover gasket, timing cover seal and a Tick Performance in house ported LS6 oil pump.
I can substitute the LS2 chain for a Katech C5R chain for an additional 105 dollars. 1034.96 is the total if you want the C5R chain for those that so choose.
Old Jul 9, 2013 | 08:03 AM
handyandy496's Avatar
Hi Martin
just found one of your sns's at my door. lots of lift .613 .620 lift.
What would the ramifications be if I run 1.6 scorpions ? Can I run the stock 1.7's without concern?
Old Jul 9, 2013 | 03:25 PM
Atdc94's Avatar
That sounds perfect Martin... I just bought the LS6 Intake so I'm going to budget for the next couple weeks and hopefully be able to purchase this kit. I really appreciate the help and the awesome vids.
Old Jul 9, 2013 | 03:41 PM
JakeFusion's Avatar
Super Hulk Smash
Originally Posted by handyandy496
Hi Martin
Stock is 1.7.
You'll be fine with proper valvesprings.
Old Jul 10, 2013 | 05:03 PM
Sales@Tick's Avatar
Hi Martin
I'd run the stock rockers all day long over aftermarket rockers.
