What to use when figuring CR? Static or Dynamic
Cylinder Head Volume 57cc
Piston Head Volume 11cc (valve relief)
Gasket Thickness .054
Gasket Bore (in.) ? used 3.903
Cylinder Bore Diameter 3.903
Deck Clearance (in.) -.010
Stroke (in.) 4
Rod Length (in.) 6.125
Intake Closing Point (degrees) ABDC @ 0.050 lift (TRex) 47
STATIC CR 11.656
DYNAMIC EFFECTIVE CR 10.433
The dynamic seems awfully low. If I change the Piston Head Volume to 2cc (valve relief) I get:
Static CR 12.602
Dynamic CR 11.271
Is that too much static? I am trying to get the highest CR with out having to get custom pistons. 8 and 2 cc valve relief pistons are stock sizes.
