cam test
Good afternoon. By know. Im sure that everyone has read the gm high preformance ls3 camshaft test with the 10 diffrent cams. I was going back over this article and noticed that for all the cams they used the comps cams 918 behive springs. If these springs are only good for .600, howdid the. Use in that test? The lingenfelter cam was .629 intake and .644 exhaust. How does that work? The newest of the comps cams 918 springs can take only. 625. Am I missing something here?
Super Hulk Smash
I wouldn't run a super aggressive lobe with a beehive.
However, if you went with a milder or endurance lobe, there are a couple of beehives I'd run and would recommend them:
PSI 1511 for lightweight LS3 valves and stock rockers + endurance profiles.
or
PAC 1519 if you need a little more spring pressure due to higher RPMs or more aggressive profiles.
or
Remember that lobe design has a lot to do with it too.
