Torquer 2 guys....HELP (Again)
Now that I've given you background, here's my questions: 1) Do you think the 7.350 pushrods are too short? 2) Do you think the dual valve springs were too much for stock lifters? 3) Car lost 13 rwhp from initial 379rwhp to 366rwhp in a week. Only thing swapped out was the dual valve springs for the beehives......lifters are still loud as ****. I think the 7.350 pushrods have changed the specs of the cam. The shop owner was nice and truly tried to work with me; however after this 19 day nightmare and spending $3K+ plus having an underpowered, lifter ticking, dyno tuned Bird......I feel very frustrated. I gave these guys 19 days of communication to fix my issues. I just don't feel comfortable with all this right now. My intent is not to trash the shop at all, hence why I did not mention their name. The guys are great. That however does not make my situation better. I post my situation to gain sound advice from the experts on how to fix my situation. My car never had issues prior to this install, but I also know with all mods we accept the inherent risks. Just sucks to be on this side of things. Please let me know what you think and answer my questions.
Last edited by Comin' Thunder; Jul 20, 2013 at 05:14 PM. Reason: typing in dark, misquoted pushrod length
You need to MEASURE for correct pushrod length. This is a very simple procedure, I recommend you do this yourself and confirm you have the correct length. Don't take it back to that "shop", its very clear that they have no clue what they are doing. Who knows what else they screwed up.
FYI, I'm running new GM lifters (0.045" preload), Comp pushrods from TSP, AFR dual springs (135lb on seat), and a 224 cam. My valvetrain is very quiet.
Good luck, hope you get it fixed soon.
V2 and V3 guys report considerably more valvtrain noise even when set up
with new LS7 lifters and proper length push rods as the cam lobes are quite
aggressive. I'm not saying you don't potentially have some pooped out lifters
but the higher spring pressures (dual or BH) and the cams lobes are really
taxing those things. Also I'd bet that 7.425 is the correct length push rod for
your set up....GL2YA
I know your looking for a answer on how to fix this but that will be difficult since your not doing the labor yourself..
There are so many variables on what happend but pushrod length should have been checked properly and lifter preload checked..
I would advise against driving your car so you don't make it worse until you can fix this..
Was the shop that did this a vendor here?
As for springs, the double springs are the recommended spring for the v.2.
I know people get away with it, but lifters, oil pump, new oil pump o ring should be changed when doing heads/cam or just a cam build...
Supporting mods do just that, support! Especially with a 10-15 yr old engine..
First: a cam swap does not take 12 hours. Although I would always suggest to replace lifters, chain and pump.
Second: you should ALWAYS measure pushrods length AND PTV clearance. Most of us don't measure ptv in our garage installs as long as the cam is a "shelf cam" like yours. Although the pushrods are something to measure unless you spoke with tsp and they guaranteed them to work. ( they will say should but you better measure)
Third: I hope you still have the double springs that came with the original kit? The double spring is what you should be using and you were lied to by this "shop" that said they were to much. If the spring is set up properly ( install height and coil bind measured) they will work great as many other people with similar TSP products will attest.
Don't drive the car until you can take it to some one that knows what they are doing.
I'm sure your not trying to bash the shop that did the work, but you really should let everyone know who it was so we don't get taken advantage of for 3k+.
ls7 lifters
arp head bolts
tsp ported oil pump
n-motion billet timing chain
tsp 7.4 chromoly pushrods
decked the heads for even surface.
stock felpro mls headgasket
pacesetter headers with catted y-pipe
svo 30lb injectors
dynotune
Most shops familiar to LS powered cars can swap the cam and springs in about a day. On higher mileage older cars, like the 4th gen fbodies, unexpected issues always come up which adds to the scope of work as well as delays in turnaround time. We usually see something as minor as a leaky gasket or bad O2 sensor to something more catastrophic like a cracked sleeve. Without knowing both sides of the story, I'm hesitant to bash on the shop doing the work for the amount of time to do the work.
Anyone know who's great with LS engines in the Dayton Ohio area? Again, I won't trash the shop. That's not my style. They are working with me at this point. I just wanted to hear from you guys who I do trust on Tech. My focus now is not to drag anybody's business through the dirt. I just am focused on finding out the correct information to make my car right. I am very appreciative for all of the opinions and personal experience shared in my thread. At least I have a starting point now to get this mess fixed. Thanks!
On TSP's website, it looks like they've done the purchaser a favor and at least limited what cams you can choose in their kits so that you don't pick a .650" lift cam with .625" lift springs, but they can't really help with what a "good match" would be unless you talked with one of their sales reps personally. There are just too many different combos out there. We have always dealt with Matt @ TSP over email and he always willing to make sure we get the right parts the first time.
