Need input
Old Jul 20, 2013 | 10:37 AM
sbf's Avatar
sbf
Default Need input
Iron 370 vs aluminum 376.i no there's a weight difference but is there any hp or torque difference with same heads cr etc
Old Jul 20, 2013 | 12:22 PM
batboy's Avatar
The 376 is a LS3? If you plan to boost it, go with the iron block. The LS3 might need a lot of extra work/parts if you plan on putting it into a gen III car.
Old Jul 20, 2013 | 09:30 PM
sbf's Avatar
sbf
It's going in a foxbody with nos
Old Jul 21, 2013 | 07:08 PM
batboy's Avatar
If you plan on a big shot, the iron block is stronger and will handle a power adder better. I would plan on forged pistons and ARP rod bolts at a minimum.
Old Jul 21, 2013 | 07:38 PM
yonerhottlt1's Avatar
The LS3 has more bore so I would imagine that's worth at least a few ponies plus it's aluminum so you'll be lighter as well.
Old Jul 21, 2013 | 10:40 PM
wildcamaro's Avatar
Give me an aluminum block any day...I've never heard of anyone damaging an aluminum block unless you're trying to run a TON of boost
