more compression
Old Jul 20, 2013 | 03:24 PM
chevybayboy's Avatar
Default more compression
I've been searching in and and but can't seem to find the answer I'm looking for, well I'm getting ready to get my ls1 346 built with my 243 heads so I think my compression is around 10:1 or 10:2 I want to bump it up to around 11:1 or close to it without milling my heads I was thinking running a thinner head gasket with forged domed pistons what do you guys think? Oh and I want to be able to still run on pump gas say 91-93 octane
Old Jul 20, 2013 | 04:27 PM
1bdbrd's Avatar
With the right timing 11:1 won't be an issue. A friend of mine runs just under 13:1 on his 408 on 91. His is due to cam timing bleeding some off.
For you, I think the LS6 came stock with 11:1 compression?
Old Jul 20, 2013 | 04:46 PM
KCS's Avatar
KCS
Moderator
First of all, and this is just bugging the crap out of me, in your sig it should be BRIAN not BRAIN.
Second, it takes a little bit of math to figure out compression ratios but luckily there are several online calculators available to make it easier for someone to determine what they need to do to achieve their ideal CR (static or dynamic). Wiseco, Diamond, Probe, etc all have their catalogs online so you can pick out a piston, plug in the dome volume into a calculator and determine whether it will meet your goals or not.
Lastly, why don't you want to mill the heads if forged piston are an option?
Old Jul 20, 2013 | 04:51 PM
KingPin1094's Avatar
I love the CSG Networks calculators. Heres the one for compression ratio: http://www.csgnetwork.com/compcalc.html
Old Jul 20, 2013 | 04:58 PM
3rdCoastPowerSports's Avatar
Brain... ha that made me laugh. I don't think he is the first though. Brian is a great guy. For those that have not experienced his spring kits they are a thing of beauty.
1bdbrd, 13:1 static on 91.....
Old Jul 20, 2013 | 05:07 PM
Lmfao you know I never noticed I spelled it wrong Lol I'm going to change it now, well 2 reasons I don't want to change my pushrods out and most shop only want to mill if i get the rest of the head work done like p&p don't really want to fork up the extra 1200 for it
Old Jul 20, 2013 | 05:13 PM
Originally Posted by bozzhawg
That should be no problem, just watch your dynamic comp and pay attention to how much your piston comes up out the hole/ deck height for your quench.
What you are trying to do is very common.
Ok just wanted to make sure i didnt run into any problems doing this
Old Jul 20, 2013 | 05:16 PM
Well I'm getting a ls1 block to replace my old block and I think the guy said since I went with the Ls6 heads it dropped my compression a bit
 Michael S. Palmer
Old Jul 20, 2013 | 05:19 PM
wildcamaro's Avatar
Ls6 heads raise compression over ls1 heads, something like 10.8:1
Old Jul 20, 2013 | 05:31 PM
Really? I wonder what he was talking about then? Well maybe I would like to boost it to around 11:5:1 and spray will not hurt this?
Old Jul 20, 2013 | 05:55 PM
Get the short block assembled.
Measure your deck height and how much the piston comes out of the hole. Or you can have your machine shop verify and measure this. I do it myself tho.This calculation will help you determine what head gasket thickness you will need to run for your desired quench estimation along with your static and dynamic comp calculations. Once I know how much the pistons are out the hole, I can kind of figure out what thickness of gasket I will run for quench.
A lot of guys do it backwards, they fixate on a certain static comp and at all cost buy headgaskets and mill heads, but never fully know how much that piston is coming out of the hole, they just guess and are surprised when **** goes bad later after the install.
Once I know the piston deck height clearance, piston dome, idea of head gasket thickness, quench, then I can figure how much I need to mill for the certain static comp. To figure your dynamic, you will need the IVC on the camshaft timing events, ICL, LSA, and duration.
Mill the heads last. You can always measure but once the heads are milled, your stuck with that unless you buy another set of heads or run a thicker headgasket but then that may throw off your quench and drop static comp.
Ohhh OK great info.. I'll have the guy building my short block do it I don't have the tools to measure myself but Yea that seems to make since, I'll have him check it out to see if I need to mill the heads.. I might just have to change prs
