6.0 vortec parts needed for ls appearance
Old Jul 21, 2013 | 01:17 AM
69greyghost's Avatar
Default 6.0 vortec parts needed for ls appearance
Hey guys what all is needed to make an lq motor appear like a normal ls2 or ls1? I know I want an ls6 intake but I am in the dark about what brackets and other dress up things are needed to give it that ls motor appearance. Guys I appreciate ur help, my friend said I needed c5 corvette bracketry is this true? Also does anyone have cam suggestions, maybe a build thread for a lq9 pushing close to 500 rwhp? Thanks guys!
Old Jul 21, 2013 | 07:18 AM
96capricemgr's Avatar
what vehicle are you putting it in? This will affect accessory fitment.
I doubt you need to specifically look for C5 brackets but if going in a car you probably want to find car brackets.
Why are you asking about close as possible to 500rwhp but then only talking about OEM intake and a cam when HEADS are going to be the most important part of that equation.
Old Jul 21, 2013 | 08:52 AM
wildcamaro's Avatar
You would be able to make 500whp with an ls6 intake as long as you have a good set of heads and cam...
Old Jul 21, 2013 | 10:26 AM
The vehicle this build is going in is a 69 camaro. Can I use camaro or trans am bracketry? I wasnt sure if it would fit because of it being a 6.0. The only thing I have some clarity about fitting is the fbody oil pan. I want one with windage tray and pickup tho. I am not opposed to going aftermarket intake but I like the way the plastic ones look. The ls6 intakes are rather pricy, are there anything similar in price with bigger performance gains?
I was thinking this was possible based off of some of the builds I have seen on here and other sites. It juts didnt seem like an outlandish goal.Thanks again for feedback guys
Old Jul 21, 2013 | 10:43 AM
01WS6/tamu's Avatar
Go visit the conversions/hybrids section on here and do lots and lots of reading. 1st gen camaros are old hat to LS swaps these days you will find every type of swap in there from factory parts whole way to full custom one off stuff. ALso make extensive use of the search at the top to find even more stuff.
But yes easiest bracket and intake set up is LS6 intake/h3 alpha oil pan/ and vette front accessories. The easiest way to get the accessories is to buy the complete package from gm performance or summit jegs they are about 850 last time I looked. KooKs makes swap headers and there are a myriad of ways to plumb up the fuel system. Wiring the whole thing depends on your abilities. My favorite way to do LS swaps in old cars is to move the complete entire inside and outside harness from a donor car to the vehicle you are building. 9 times out of 10 the car needs a complete harness anyway and doing it the above way makes it piece of cake plug and play and factory gm reliable.
