The Disassembly [SiXXX]
Old Jul 26, 2013 | 03:19 PM
pauls99z28's Avatar
Sweet! Thanks for the link.
Oh..Did you drop the cradle on your own or had help? How long Did it take you?
Old Jul 26, 2013 | 03:27 PM
WS.SIX's Avatar
100% on my own. Did it over about 3-4 days working a couple hours a day. Could have done it a lot quicker but had to stop in the middle of a lot of things to wait for shipping.
Old Jul 26, 2013 | 04:11 PM
WS.SIX's Avatar
New wideband just came in!
Still waiting on UPS to deliver this pulley puller though. Slowasses!
Old Jul 26, 2013 | 10:06 PM
WS.SIX's Avatar
Pulley puller finally came in about an hour ago. Assembled it and got to werk!
Locked up the flywheel
Hooked up the pulley puller, a 22mm deep impact socket and a bolt I had removed earlier from the A/C system. To hell with buying another bolt just to pull the pulley off.
Came off like butta, didn't slip once!
My engine must have been put through hell by its previous owner I have never seen internals this dirty before.
Got the timing chain, cam gear and oil pump removed, ready to remove the cam. (slid off the cam retainer as well right after the pic)
Pretty normal wear on all the lobes except the one culprit #8 intake lobe. ***** F'D!
Lifter wasn't too bad though!
LMFAO just kidding ***** F'D!
I inspected the bottom end (checking for play in rod bearings) everything seems pretty normal. Cam bearings dont show adverse wear either. Think I can go without a rebuild? Do a few quick cheap oil flushes and see if a rod windows the block? lol
Old Jul 27, 2013 | 12:41 AM
01cherryreds10's Avatar
Don't bother with the LS6 valley get a catch can and be done. It's not worth the money for the cover.
That thing does look pretty nasty inside lol
Old Jul 27, 2013 | 01:16 AM
WS.SIX's Avatar
I don't want the extra tubing wrapping around the engine the ls6 valley cover is much cleaner. Can mount a Norris catch can to the passenger side head for a super clean install if need be.
Old Jul 27, 2013 | 01:23 AM
99WS6_'s Avatar
1 question how did you pull the whole front end while having the engine lift in front of the car?
Old Jul 27, 2013 | 01:26 AM
WS.SIX's Avatar
Uh... Sideways? You can see the progression in the first few pictures.
Old Jul 27, 2013 | 01:34 AM
99WS6_'s Avatar
Ha I forgot about the dolly I got confuse the wheels look like they were on the ground
Old Jul 27, 2013 | 01:38 AM
WS.SIX's Avatar
Oh they were still touching the ground alright. Almost gave myself a hemmy getting it out
Old Jul 27, 2013 | 06:23 AM
nascarnate326's Avatar
How many miles on this motor?
What cam are you going with?
Old Jul 27, 2013 | 06:39 AM
  #32
sgtrgpfdps's Avatar
I'm impressed in what you can do. Where did you get the know how to do something like this. I'm the type to screw up a oil change some times !
Old Jul 27, 2013 | 09:43 AM
  #33
Gunslinger09's Avatar
Shoot if the crank and everything looks good give it a light hone then throw in a set of forged pistons and rings along with new bearings and go on with your bad self.
Old Jul 27, 2013 | 09:55 AM
  #34
ds98formula's Avatar
In for the progress
Old Jul 27, 2013 | 09:59 AM
  #35
WS.SIX's Avatar
Motor has ~118K on it.
Will be slapping in an ASA cam. Decent power, great sound and very easy on the valvetrain. Will be running morel linkbar lifters, chromemoly pushrods, stock rockers with comp trunions, ls6 springs with some new valve seals/seats. New knock sensors & harness, new gaskets all around, new ls2 timing set and probably melling oil pump, improved racing oil pan baffle, pickup tube girdle.
I don't plan on doing anything serious with this block (rotating assembly, huge high lift cam, etc)... when something goes seriously wrong its getting an iron TMS block dropped in with all new goodies.
Old Jul 27, 2013 | 10:08 AM
  #36
So what heads are you running? Do you plan to do any port and polish work on them or just resurface and valve job from the local machine shop? I am interested to see what kind of power you get out of the set up with the ASA cam.
Old Jul 27, 2013 | 10:10 AM
  #37
WS.SIX's Avatar
Going to run it cam only on stock heads for a couple months while I send off another pair of heads I have to AI for their HCR 219 work.
Old Jul 27, 2013 | 02:24 PM
  #38
zzcamaro00's Avatar
yes thank you for picking up some real good lifters. your doing it right man.
Old Jul 27, 2013 | 03:09 PM
  #39
WS.SIX's Avatar
Yeah not going the LS7 or SLR route plus not having to buy any lifter trays is a plus.
Old Jul 27, 2013 | 09:54 PM
  #40
Roarin_8's Avatar
Wow that lifter committed suicide!!!
