Streetsweeper HT or SNS stage 2
Thanks for the notion guys. I feel that the SNS Stage 2 camshaft is the best all around camshaft you can have for a 6 speed stock 3.622" stroke street car.
Under the curve power, mid-range power, top end power to 7000rpm if you want it with ported heads and a nasty idle to boot with great drivability on top of all of that.
You guys know what my pick is....![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
That said, if you have an automatic with a 3600rpm or higher stall I'd recommend the LS2 SNS stage 2 cam as it has a later intake valve closing event and will work better in my opinion with a stalled automatic than a 6 speed car.
I've had a few customers make 400-410rwhp/375-385rwtq with stalled 4l60e's cam only with the LS2 SNS Stage 2 camshaft.
#32
streetsweeper-236*-240*-111*-.631"-.610"
streetsweeper HT-228*-232*-111*-.612"-.600"
Two completely different cams and shouldn't be used as a comparison imo. You cant go wrong with either cam your looking at though. SSHT is a great classic cam that's been around awhile and martin has amazing service with alot of great cams coming out of his shop.
#37
#38
When I emailed Ed he told me why he doesn't post much on here, so you won't be able to get a lot from him on here about things. He is very helpful though and provided me with a great deal of info about what makes his cams superior.
