Stock LS1 Valve Spring Specs
Old Jul 23, 2013 | 09:06 PM
brendo389's Avatar
Default Stock LS1 Valve Spring Specs
I recently broke a ls1 valve spring, and need to know the specs for a replacement valve so I can get the car running properly again. I have a 2000, ls1 6 speed car and it's got a stock cam. I'm assuming the years have different cam specs and whatnot, so please inform me of the correct details so I can order the right part! Thanks!
Old Jul 23, 2013 | 09:56 PM
PREDATOR-Z's Avatar
valves are 2.00/1.55 and you do not just change one spring you change them all. Put a set of LS6 or LS2 springs on and you'll be gold.
Old Jul 23, 2013 | 10:31 PM
garygnu's Avatar
correct ^^^^,change are the springs.check SDPC or TSP for stock GM springs.how many miles on the motor ?if very high mileage consider new valve seals ,and new rocker arm trunnions bearings.check for push rod straightness .
Old Jul 23, 2013 | 11:09 PM
wildcamaro's Avatar
Ls6 springs from summit are a measly $65...well worth the $$$
Old Jul 26, 2013 | 10:40 PM
brendo389's Avatar
Would I need to change anything for those springs to work?
Old Jul 26, 2013 | 11:52 PM
PREDATOR-Z's Avatar
No, they are direct replacement.
Old Jul 27, 2013 | 07:28 AM
vettenuts's Avatar
I agree, the stock springs weaken with time/miles anyhow so this is a good time for a replacement. I used the LS6 springs when I rebuilt my stock 241 heads.
