Considering ditching my 228R for...
Truck specs are as follows
cam is on a 112 LSA
.030 over LQ4
LS2/LQ9 replacement pistons
forged scat rods
stock crank
317 heads, milled enough to clean mating surface
I've forgotten which springs, but I believe they're PAC 1518
Most definitely a bee-hive style as opposed to dual rate
stock truck intake
stock T.B.
SLP Maf
4L80E trans, stock converter
Plans for a 2500 rpm stall
38" tires
4.56 gear
This is all in probably a 5K truck.
I originally bought the 228R off here impulsively, I'm considering changing now because I feel as if it's actually a fairly tame cam for a 6.0.
Suggestions? I was considering something along the lines of a 230/234, wanting a larger cam, would prefer it to have a choppy idle...
Thanks in advance!!
When it was a stick it was wicked, seemed as if the power pulled throughout, however it lasted 75 miles so I didn't really get enough seat time to really tell.
I say tame, just as there seems to be a trend that with the extra cubes of the 6.0 vs 5.7 people seem to opt for a larger cam.
Truck is a DD/weekend warrior, I'd like it to have street manners, while still having a nice broad powerband. As well as needing torque at a lower curve than cars, due to the larger tires and their added mass.
I've got 2 weeks left for this semester before I've got 3 weeks off, truck isnt back on the road yet due to lack of tune for the automatic. I could do the cam swap in an afternoon, just would prefer to make the decision soon don't want to have to re-tune the truck twice.
big cam in a heavy truck on heavy tires without much stall converter isn't a good combo...and while a 6.0 can absorb more cam than a 5.7 the difference isn't a huge one
I'll be Pred-Z would be interesting to hear on this.
Granted I am running a huge cooler, -6 lines, and a fan for said cooler, I just worried with the larger converter it would slip too much at highway speeds.
"Butt dyno" I like that.. I see your point with the smaller cam, however when I actually beat on the truck it is rarely below 3-4K, along with in situations where I'm starting from a much lower RPM and need the extra "oomph" the case is in 4LO, which multiplies the final drive by an additional 2.71.
I am with this guy. You need less cam not more. You want to bring the peak down not push it up above 6k. It would make a huge difference...you dont want to have to rev your truck to the moon to get going or pull...and 228r with a 2500 stall in a truck just seems mismatched. You need a small intake lobe, I might go wide on the lsa, but point is so it pulls like a truck. Itll be done at 5500...but its a fuggin truck! 10 more hp a 7k aint worth ****.
Unless you go with Jakes idea and add another 200hp you need less cam imo. Especially if you ever use this vehicle as a truck. You need to drive it auto I guess its going to be a dog compared to the stick.
