HELP!!!Need to choose a cam!!
Old Jul 30, 2013 | 10:20 AM
91ls1silverado's Avatar
Originally Posted by Martin@Tick
If it weighs 5000lbs. then my recommendation is the Stage 1 SNS cam or more compression and the Stage 2 SNS cam.
And also how much do i mill the heads? .010? .020
Old Jul 30, 2013 | 05:35 PM
Sales@Tick's Avatar
With the Stage 2 cam, stock sized valves and a stock head gasket you can mill .015" off the heads. You could also run a .040" gasket if you wished.
LS1 correct?
Old Jul 30, 2013 | 07:41 PM
LS1 correct?
Oh ok thanks. And yes it is a ls1 off a 98 trans am. I might go to the scales to weigh my truck just to see how much it really weighs because 5000 pounds sounds alot to me.
Old Aug 1, 2013 | 10:49 AM
Sales@Tick's Avatar
It does sound like a lot of weight.
Old Aug 1, 2013 | 11:42 AM
JakeFusion's Avatar
Super Hulk Smash
I'm betting it's closer to 4200-4300.
I had a 95 Dodge Ram that was about 4280. Trucks and cars have gotten heavier as safety regulations have gotten more stringent.
Old Aug 1, 2013 | 02:01 PM
It says it weighs from 3600-3800.
Old Aug 1, 2013 | 02:02 PM
Thanks and yea mine is around 3800
