What would be a good cam for a 6.0
14 Second Truck Club
I had metioned in an earlier post about wanting to get a used 6.0 this summer.
When I do come across a 6.0, what size cam to go with? By then I will have the 2600 stall and gears (still debating on either 3.73s or 3.90s).
I want a cam with no more than .530 lift (I'll get the heads milled .030-.035 to raise compression & other headwork) and that would make a ton of mid-range torque and nice upper rpm horsepower. I just don't want nothing that peaks at over 6000 rpms and takes over 2500 to start to kick in some torque(I do tow some things now).
I was thinking of the 216/220 114 LSA low-lift cam, but didn't know if anybody had any other suggestions about other name brand or custom cams. I don't want nothing too big, just enough for a daily driver and a ton of mid-range torque and nice top-end power. If I do get one, I plan to keep the stock bottom-end (364).
Thanks
Thanks
