Part location help
Old Jul 26, 2013 | 08:43 PM
owlpuff's Avatar
Default Part location help
I need some assistance in finding parts: I have a $600 budget right now, and so far I can only find a machine shop that will do the honing/reassembling for $300+ if i disassemble before bringing in. And that place was kinda shady sounding. Is putting the engine back together something I should attempt? The main thing I need is honing to remove rust from the cylinder wall. So far shopping around Ive found the below:
Engine stand for work at home: 60
http://www.harborfreight.com/1000-lb...and-69886.html
Cherry picker for $180 from Northern tools:
http://www.northerntool.com/shop/too...5491_200305491
And rings I found for $125
http://www.ws6project.com/user_stor/...-piston-rings/
Now as for ring size, I should get the measurement after honing and get rings to that size correct?
Old Jul 26, 2013 | 08:59 PM
Burken01's Avatar
If you have never assembled one I wouldn't recommend practing just yet..
I would research that before you start since you'll need a bunch of special tools and if you mess up and need to do something over it can get pricey really quickly..
Old Jul 27, 2013 | 12:38 PM
2000PewterT/A's Avatar
If you have never worked on a engine internally before don't start experimenting now. That machine shop's prices seems a little low for machining and a reassembly. Do they do ls work often? If they never machined a ls motor I would not got there. Number one thing is do the research and make sure where you take your engine has a good reputation with ls motors.
