Summit Racing 6.0 LS Block
and just a personal experience with piston to wall..... I worked on Manny Buginga's super street outlaw car and we had a major issue at a race where we lifted the ring land on two pistons after qualifying, this was just freshened up using the last spare that we had weeks before so we had nothing in the trailer but the old set of pistons that were .010 smaller, we honed the cyinders to clean them up and installed the old pistons with the same rings..there was .018 piston to wall, we ran it all through eliminations winning the event and then ran it 4 days later qualifying again for another race until we could get the spare engine back to us.....we never even lost a mph during the 10 plus passes but then again I guess 2000+ horsepower and low 7 second et's may not be performance enough.
We are glad to see there is interest in our Summit Racing LS Engine blocks and want to address any concerns. A few of the things we have picked up from the posting so far are below and will do our best to provide additional information as needed.
The blocks are an iron 6.0L truck block bored to 4.030" and clearanced for up to a 4.00" stroke with H-beam rods. They are drilled for use with a truck accessory serpentine system. If your build requires a different drive belt layout you may be required to purchase specialty brackets or drill and tap new mounting points.
You should wait to purchase your head bolts until after receiving your new block since it could use either one of the two bolt lengths available. The instruction sheet that will ship with your new block will inform you of your block's head bolt style.
Our block is going to be machined using a deck plate system and the cylinders will be finish honed using the following equipment: Sunnen CK-21 or Sunnen CV-606 Ra spec max 30 after hone, max 25 after brushing. New Durabond Cam bearings and a new steel freeze plug are installed by our supplier.
All of our blocks have been checked for damage and are not used if inserts or major repairs are needed.
If you have any further questions, please post your reply and we will do our best to get you the answer you're looking for.
Thanks!
And my original point was that. The point of the summit block is to avoid machine work...so if you have to touch it, aren't you just defeating the purpose of it?
I'll stick to fitting the bores to the pistons to ensure everything is what it is supposed to be. And not have to rely on what summit tells me.
Doing it the GM / Summit way is fine for mass-production but it's one of the reasons why these motors with short piston skirts develop piston slap at low miles. On any performance build where you want specific clearances you should always machine the bores to match the pistons.
