LQ4/ ARP help please
I have begun my short block build and I have already run into what "may" be an issue.
I'm putting ARP connecting rod bolts in.
the factory bolts have no taper close to the head but the ARP does.
there appears to be a bushing in the rod cap that centres the factory bolt. as I went to install the arp bolt it pulled this bushing out.
I have never read of there being an issue doing a straight bolt swap in this engine.
with that being said, the shoulder on the ARP is .351 and the combined thickness of the factory rod bolt and this bushing is within a thou of that.
so do I yank these bushings?
Thanks
Warren
Thanks
Warren
