2002 Z28 Camaro: Car help!!
Im only 16 and this is my 1st car so bare with me. So my car had sat for 2 years until 5 days ago brought it back to life! This morin i went to crank it up and it shut off. Im talkin all the lights, gagues, radio. Everything! I'm guess its a bad connection. Cause I can still lock and unlock it with the keyless entry.
Somebody please. I'm trying to make sure this thing works and running before school starts.
try cleaning the battery terminals. If they look corroded use a wire brush to get all the gunk off first. the disconnect both terminals and give them a quick brush. pm me if you need somthing specific.
ditto, I had a new battery that i let sit for a bit and the next time i tried to start it up similar problem and it just crapped out. put a multimeter on the battery and or take it in. also check your grounds
