MTI T1 Users Please Come Inside!
Old Mar 9, 2003 | 07:01 PM
Str8crusinT/A's Avatar
From: Oklahoma 1000+ posts from LS1.COM and 430+ posts from WWW.COFBA.COM
Default MTI T1 Users Please Come Inside!
I just bought a used cam and was wondering if on the MTI Cam it should read
LUNATI QANP "on the top part at the end"
2870 A " upside down under the Lanati Qanp"
RRS1-221-221 112 "at the very bottom"
I was wondering if this is indeed the MTI T1 cam from MTI themselves or does this mean that Lunati made this cam?
Please help. I was wondering because somewhere I heard that the T1 cams made by other companies were not the same/correct grind numbers as the ones the MTI made themselves.
What do you think?
<small>[ March 28, 2003, 12:30 PM: Message edited by: Str8crusinT/A ]</small>
Old Mar 9, 2003 | 07:04 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: MTI T1 Users Please Come Inside!
I beleive the older T1 cams were made for MTI by Lunati. Newer T1/B1 cams are made for MTI by Comp. Not exactly sure when the switch-over was though...
Old Mar 29, 2003 | 12:29 AM
So does this mean the cam I have is not ground properly?
