Need some opinions
So long story short, I bought a 98' LS1 that was incorrectly re-assembled for very cheap. I'm selling off some parts I wouldn't need with either direction I go and am almost even on the deal plus I have a shortblock that would run.
The 5.7 will need a crank and a set of rings because I was an impatient idiot and broke a ring using a jenky piston ring compressor, but that's not a big deal.
My car made 406rwhp/367rwtq on a Dynojet dyno with the following combo:
Stock bottom LQ4
231/234 .617/.612 112LSA EPS cam
Fast 102 intake w/ NW 102 tb
36lb injectors
PRC 243 heads (unsure what stage I sent them my cores during a porting sale)
1-7/8 longtube headers
2.5in exhaust with an x pipe
4000 yank stall in a 4l60e
The car ran 11.28 and I think I trapped 117mph, had a 1.50 60'
My question is, if it were your car, what would you rather do:
Squeeze out a 10 second pass by gutting the interior, adding some lightweight parts, try some different drag radials, double adjustable shocks in the rear, tighten up the front drag shocks, cutouts etc etc
OR
Pull the 6.0 out and transfer everything over to the 5.7, maybe gain a little power with the added compression and save over 100lbs vs the iron block
I have no idea what I will do if I will really do anything and right now I don't have time for either, but I just wanted to see what everyone else thought.
I really want to build something other than NA, maybe a small nitrous plate setup or an ebay turbo deal but everything in the car was built with NA in mind (trans, rear end) and I would rather get a cheap roller off of CL and do that.
Sorry for the long thread but when you are bored but don't have the time or money to do something to your car this is what happens
The 5.7 will not make more power than a 6.0 with the same top end. The added cubes will out perform the smaller engine. I'm sure some Internet guru will debunk me on that though.....
I would take a stock compression ls1 over a stock or even slightly higher than stock compression lq any day of the week for a N/A build
So has no one really weighed an iron block and an aluminum block on the same scales? It seems no one on tech can agree on the real weight difference. People have spouted off everything between 60lbs and 120lbs. Most common seems to be 80lbs.
I'm the block weight sticky someone posted saying the aluminum was lighter by 100+ lbs
Using the same cam specs and heads and putting in the specs for an LS1 I got 10.40
So lets say rule of thumb is for every point of compression, a 4% power gain. Seeing the car makes 406rwhp, and I would only gain .4 of a point of compression, that would probably equate to a 1.6% gain in power. It doesn't seem like much but doing the math it comes to a 8rwhp gain.
Now surely it's not worth all of that work for that little bit of gain, but what would happen if I had the heads milled .020 or .030
I bet your DCR is closer to 7.8-8.4:1 and not 10:1.
http://www.yellowbullet.com/forum/sh...d.php?t=517325
Oh, and the comment about "most 6.0 builds I've seen have been dogs" or turds or what ever I call BS. My lq4 with boltons,converter and tune has made quite a few haters and is in the thread I li med to you can see the lq4 engines are just as good a candidate for heads and cam or just cam-only.
Point I was making was a lot of people throw their ls1 parts onto a lq engine and then get confused why it doesn't make more power or it isn't faster just because it has a few extra cubes. I'm not claiming to be an expert just pointing out what seems to be a common mistake of people swapping to a 6.0l longblock.
And it also depends on the uses of the car. I don't want any weight back on the nose of my car if I can help it, especially not ~80lbs. The aluminum block was part of the draw of the ls1 for me.
Agin
Typical 5.7 "top end" on lq4 and imagine what a cam for the engine combo would do.
Good luck! Have fun! I hope it all works out the way you want!
