Feedback on polluter v2
Old Aug 29, 2013 | 04:15 PM
HCI2000SS's Avatar
Originally Posted by slatesekx
I just went with a TMS 370ci LQ9 with a custom cam that's very similar to a M3
What is your exact setup? I have a TMS 370ci LQ9 with PRC 5.3 heads, and a cam that is very similar to a M3 as well
Old Aug 29, 2013 | 04:35 PM
chevybayboy's Avatar
Originally Posted by 97camaro383
I'm not sure what tick has bigger then the polluter v2. I'd read he has a stroker line of cams. I think the v2 would be a good can for you
Thanks for the feedback.. question being that I'm going with bigger cubes would that still make the polluter a Max effort can?
Old Aug 29, 2013 | 05:05 PM
97camaro383's Avatar
I compare the Polluter v2 to cams like the ms3 & ms4. Tons of people run them in 6.0 and make great power, could they make more, probably. Im sure the extra cubes would tame the cam down some but itd prob make it a more streetable cam and still make great power. I actually wish I would've flycut whatever it took and ran the Polluter v2 in my car. If you still think you'd want a bigger cam then tell Martin you'd like a little bigger cam then the v2. He'll spec you something im sure, but overall he specs cam and setups for a living so most times he'll put you on a setup that'll work and fit what you want.
Old Aug 29, 2013 | 10:29 PM
OK thanks man I'm pretty set on the polluter know I want it still streetable and tamed I'll probably got with the polluter on a 111 lsa
Old Aug 30, 2013 | 06:16 AM
Ronny_02_WS6's Avatar
Polluter v2 for LS2 Sounds Good for a 383 like 99Bluz28 stated!!!
