Swapping from Iron LQ4 to LS1 heads
And.....how about the LS1 heads with a Comp 212/218 .558/.563 114lsa XE High-Lift cam on a 6.0 block ???.....
and Big Tex.....don't EVEN say it
STOCK LS1 head (from the Chevy High Performance Website)
STOCK 6.0 heads (courtesy of Jason99ta...even if he doesn't realize it
To me it appears that the LS1 head outperforms the 6.0 head by quite a large margin at low and high lifts (mid lifts it loses a little to the 6.0)
I would like to use the #241's I have for a couple of reasons.....I ALREADY OWN them, they will have a higher CR due to the smaller chambers, and they are ALUMINUM (ignore all of my previous posts about IRON guys OK)
I am also interested in doing a mild P&P job to these #241's I have....even without a decent port job they shoud still outflow the iron 6.0's.......correct ???
The iron 6.0l heads flowed VERY similar to the 853 LS1 castings. The 317 6.0 aluminum castings were the heads I flowed above (6.0l flow #s).
Some minor cleanup work on 241 castings will work much better than the stock, iron 6.0 heads.
Jason
that was EXACTLY what I wanted to hear !!.....given the budget I am currently on the #241's are gonna be the head of choice
BTW...do you have flow-data for the iron lq4 heads ???....I know you said they flow VERY similar to the #853's but I'd love to see the numbers.....
However, we had a hard-drive failure and lost flow #s for over 200 LS1 heads (including the stock #s) awhile back. The ones I had printouts of were the ones I posted above.
