408 build questions
Old Aug 29, 2013 | 11:17 AM
whiteta01's Avatar
Default 408 build questions
hey guys im getting ready to start a build on my 01 trans am a4. i talked to derek at tsp about the build, i want to go with, 408 lq9 with prc 247 heads and texas giant cam. i already have the fast 92/92 and tsp lt 1 7/8. its going to get bolted up with a th400 and custom stall i havent had a chance to talk to anyone about yet. i would like to put a 200-250 shot on the car as well it wont be a dd its only for drag and to shut up some ppl in my town on the street. it will also be gutted and 9 inch put in with slicks. can i get anyone that knows about what kind of numbers ill be expecting or 1/4 et times. i would really want to be able to hit 9s? thanks for the responses guys.
Old Aug 29, 2013 | 11:55 AM
bww3588's Avatar
Custom grind cam or no cam at all. You have an excellent short block with an excellent set of heads, and you're going to stuff an old as dirt shelf cam in it?.
Do yourself a favor and call Geoff@eps, patg, Martin@tick...whoever, and get a custom cam.
Old Aug 29, 2013 | 11:58 AM
whiteta01's Avatar
thats what i was going to do i was going to go with a pat g cam. i want a big cam and i want it to sit there and lob lol just wanted inputs on any better ideas to go with
Old Aug 29, 2013 | 12:31 PM
whiteta01's Avatar
anyone have any other segestions
Old Aug 29, 2013 | 07:02 PM
Roger Blackmore's Avatar
My 408 with TFS 225s and a turbo 350 in a 3500 pound car ran 10.7s on motor and 9.80s with a 150 shot through a nitrous outlet plate. So I'd say that combo will reach your goals, and then some.
Old Aug 29, 2013 | 08:21 PM
whiteta01's Avatar
What compression are u running
Old Aug 30, 2013 | 06:43 AM
mark21742's Avatar
I ended up going with 12.5:1 static compression on my 408 with a 255/271 .624/.624 115 lsa cam which gave me a very pump gas friendly 8.22:1 dcr. Did have a 4l60e behind it with a 4, 000 stall and it sounded great and pulled hard as hell all the way to my 8, 000 rpm fuel cutoff.
If that helps.
Old Aug 30, 2013 | 07:08 AM
whiteta01's Avatar
How many rpms can u turn with a 408??
Old Aug 30, 2013 | 07:14 AM
I'm running 13:1 compression and turning it 7200
But I know of another f body running 10.6s on about 11.8:1 compression. It only has the TFS 215s.
Old Aug 30, 2013 | 07:16 AM
mark21742's Avatar
I jave my fuel cut set to 8, 000 rpms right now...if I ever get the car on a dyno I might raise the the fuel cut to 8, 500 or even 9, 000 rpms if it is still making power.
Its not the engine size, but it's the parts you use inside it that determines the max rpms
Old Aug 30, 2013 | 07:40 AM
whiteta01's Avatar
But is the car with 13:1 running spray??
Old Aug 30, 2013 | 09:06 AM
Yes. Mine ran 10.7s on motor, and 9.7s on a 150 shot.
Old Aug 30, 2013 | 09:25 AM
whiteta01's Avatar
what kind of gear are you guys running with the three speed?
Old Aug 30, 2013 | 09:38 AM
I've run the times posted above with a 3.73, and a 4.10 gear. If you are going to be spraying a lot, the 3.73 is the better gear. Not sure of the rpm on the 150 shot, but I upped the shot to 250 for a while. It was running 9.60s @ 140. I believe it was turning about 7000 rpm through the trap's.
Old Aug 30, 2013 | 11:32 AM
whiteta01's Avatar
Thumbs up
thats what im looking for right there
Old Aug 30, 2013 | 11:40 AM
Yea, the combo you have listed above should have no problems reaching you goals with drag type bolt on suspension parts.
Old Aug 30, 2013 | 11:45 AM
whiteta01's Avatar
how big of a cam do u have
Old Aug 30, 2013 | 11:51 AM
That cam was a hydraulic. 248/256 duration. .602/622 lift. 114+2 lsa. This combo was built in 2006.
Old Aug 30, 2013 | 11:55 AM
whiteta01's Avatar
nice setup. what rear end?
Old Aug 30, 2013 | 12:00 PM
Moser 12 bolt. Like stated earlier, 3.73, and 4.10s. It had the Detroit Locker True Trac when I put it in, and I switched over to a spool later on. If your car is going to be track only, I suggest going with a spool from the get. They are cheaper, and lighter.
