LM7 & LQ4 (stock form) engine performance charts @ LOW RPM
Hi guys,
Could you please share with me some engine performance charts for the LM7 & LQ4 engines, that includes performance at LOW RPM ( 1000-4000rpm charted). All the charts I have found are for peak values (high speeds), and most of them are charted from 2500/3000 rpms and up.
The vehicle I'm considering for the swaps spends 99.99999% of its life between 1500 & 2500 rpms. ( Off road crawler vehicle)
I know these Gen III engines are great at high rpms...but wondering what are the specs at "real life driving" rpm's ???.
thanks in avance for the help.
Pedro
Pedro
[QUOTE=99Bluz28;17659426]This might help:
LM7; 270-295 hp, and 315-335 tq, depending on model yr ..
LQ4; 300-325 hp, and 360-370 tq, depending on model yr..[/QUOTErque]
Thanks for the post, but I believe you posted the peak values, and these are produced at high rpm (4500 rpm aprox)....
I need to know the torque at 1500/2500 rpms
I dont have the numbers but i can tell you from expirence and rock crawling myself(see signature) thst you will want a 6.0l. Like i said i dont have actaul numbers but its obvious with the butt dyno 6.0's pull alot harder sooner than 5.3's which need some rpms and a little higher stall converter.
The more power you can make at a lower rpm is where it is rock crawling. You do not want to turn the engine to the moon while moving at a very slow speed. Not only does this increase heat and wear on the engine, but you also need a gear ratio that allows you to crawl, and get wheel speed for mud and heating the tires up on rocks.
