Going crazy with pcv and breather questions on 1000hp cars
I have gone through so many threads about this topic and got NOWHERE!
Heres what im looking to figure out... On lets say a 1000hp Nitrous Car what is the best way to set up the pcv or breather set up. Heres what I have
Fast intake all ports capped off.
Ls6 Valley with pcv capped off.
Passenger side has a breather on it and the other port is capped off.
My driver side valve cover has no ports what so ever.
I have a catch can but have it removed at this time.
From what im reading it would appear I need a port on the driver side valve cover to add another breather to be correct with the breather set up? or run 2 10an lines down to a catch can with breather.
Or would the ls6 pcv setup work with this much power? i have a fear of oil in the intake and blowing seals out with this setup.
Thanks in advance
Thanks in advance
Thanks. I am planning this after some more research I did. But might be using my catch can in between the ls6 pcv valley and the intake seems others have had good results with this set up but if i see one spec of oil in that intake its gone.
