Blown head gasket?
Old Sep 16, 2013 | 08:54 PM
ZHAWK154's Avatar
I have seen a lot of cats fail on stock cars with no other air/fuel problems. That being said its gonna be hard to diagnose any other faults with that clogged up cat on there. Backfiring, misfiring all that is associated with 4 cylinders not able to get rid of exh gasses. I'd replace the cat asap, clear codes and monitor fuel trims. Just my .02 good luck!
Old Sep 17, 2013 | 04:00 AM
vettenuts's Avatar
Originally Posted by wayland1985
Hmmm. Seems I have a bit of probing to do here...
The rotten egg smell was never all the time: just a handful of instances.
I'll search tomorrow for a leak. Somewhere. There is a K&N filter on it that I just cleaned too, so maybe I didn't cinch down a bolt, or cracked a vacuum line.
Over oiling the K&N can result in coating the MAF and poor readings. You may need to clean the MAF with some electronics cleaner.
