Thinner Head Gasket for Milled Heads?
my vote: .033
If he is running a 230/230 .570 on a 110 or 112 then he will hit all 8 pistons. As far as is a MLS gasket worth it....yes even if you are running the stock thickness. Power increases from CR are far more than peak power.....5rwhp at the top doesnt even begin to tell what happeens to the area under the curve. Low end power is where the real difference is. The MLS cometics are also reusable (as per cometic and by personal experience) and I have done many head removals on the same set with no issues and it is eventually worth the money just in not having to scrape off the graphite crap from the stockers or not having to pay out for each head removal you make.
1-wont blow under boost or nitrous so easy
2-reusable
3-clean-up is non-issue
4-CR changes from gasket thickness changes are reversable unlike head milling
5-reducing quench area is more power while being less octane sensitive than milling heads where the quench area stays the same
6-most people run far too little CR especially for a motor that protects from detonation:
I have a laughathon watching guys put in huge cams like 231/237, Trex, all of these g5 cams and run the stock CR or near it. They wonder why it doesn't put down any power or at least near what the 'test' car did. Lou uses 11.45 for the G5X3 cam on a 114. Try running 12.2:1 + fot the Trex and gain 35rwhp on peak with gobs of TQ down low. Yes, all this on 93 due to overlap reducing the dynamic CR.
2-reusable
I knew that he was not going 230 duration. Milling heads does reduce quench. Same idea as putting thinner gaskets on. The Best V8 Stories One Small Block at Time
Get other opinions on this if you don't believe you are wrong.
My question is since i raised the quench height is that why im still gettin detonation?
My car went from 460 RWHP 440 RWTQ @ 21 DEg of timing after adding the thicker head gasket the car made only 440RWHP and 412 RWTQ. At the same timing numbers.
Im wondering if im better off removing the cometics and going back to stock graphite and just lowering the timing.
Any opinions on this?
If the quench area is too big: meaning you increased the quench area by going to a greater than .054" thickness in the P/H distance then you could be getting detonation from a second ignition front caused by too big a quench. For example: If you shaved the deck by .009 and the piston is .007 out of the hole then you have a P/H distance of .016. With the stock gaskets or any gasket with stock thickness that would be a quench of .038.....awesome. Lets say now to lower the CR you use cometics (or any brand with .071") you now have a quench of .055...too much and that can cause detonation, not from CR but from a second ignition source. Some people get away with it but some don't.
I am notorious for running high CR and never saw that severe a KR. I think you should check into:
1-knock sensor swap
2-A thinner gasket nearer to stock or thinner.
3-put in higher octane fuel just to test if your detonation is real or just being reported by a faulty sensor.
List the specs of your entire set-up like Cam, CR, heads, and tuning issues you had. I'll bet you can run the higher CR due to cam overlap and the detonation isnt real. The loss in power is from the loss in CR and the loss in TQ tells the whole story. Near 12:1 with a 230+ cam on a 112 should have no detonation problems.
The cam is a MTI X1 on a 112 LSA. It does open the intake valve very late and causes high pressures. I assume that this doent help.
Basicly my car made 460 RWHP with stock gaskets and 21 deg of timing and slight knock.
Now it makes 440 RWHP at 21 deg of timing it has a slight knock.
Sounds like i might be better off going back to stock gaskets and lowering the timing to 20 deg and see what kind of power it makes.
