Torquer v3 DD?
Old Sep 15, 2013 | 11:59 AM
PREDATOR-Z's Avatar
228r is only 4 degrees overlap. Tighten that to 110+2 and squeeze even more out of it. That will make it 8 degrees overlap and 42 ivc.
My favorite would be 109 lsa/109 icl, 10 degrees overlap, equidistant IVO/EVC from TDC and 43 IVC. I think this would be a good 'all around' cam.
Old Sep 15, 2013 | 07:06 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Originally Posted by badazz81z28
Drives like stock in my LS and makes 460 rwhp/runs 11s. The low end power is lacking IMHO. I can't imagine what the v3 would be like. I went 228r for the low end
Definitely not trying to be a dick here, but after WITNESSING 3 cars at different times being tuned with a 228r, that's EXTREMELY high. As in, an extra 50.
I read this right, correct? 460 with a 228r?
More info on set-up and who tuned it...?
Old Sep 15, 2013 | 07:51 PM
handyandy496's Avatar
Default imo
Seems to me that anything 12ish or better just shouldn't be a daily driver. If your not running real sticky tires its all just a waste of hp. Tires will cost you 400.00 a year easy (DD). Gas, springs, stock rears and trans....I myself like to pace myself and do the weekend warrior thing. Gives the car more fangs just driving it out of the garage when needed.
Question.... Would it be wise to swap your intake springs for your exhaust springs @ around 6000 miles on some of these more aggressive intake cams?
One more Question
On my new build would it be wise to go with stock ls1 specs(piston .008 out cold). .030 head gasket w/241's stock deck unmilled. Squish of .023 cold .033 hot for apr 11.5 comp cold 9.5 hot? using a tic torque '227/235 110+4 ? ....93 oct?
Old Sep 15, 2013 | 08:43 PM
badazz81z28's Avatar
LS1 - 346 Ci
PRC LS6 2.5 CNC Heads
FAST 102 Intake/FAST 92 TB
42lb injectors
228R
85mm MAF/CAI
Long Tube Headers 1-7/8"
True 2.5" Duals, No Cats, Ultra Flow Mufflers
SLP UDP
TKO 600/8.5 10 bolt w/3.73 gears
Tuned/Dyno'd by Cal-Speed in Bakersfield, Ca
***Disclaimer....Also consider this is a brand new engine, not a 100K mile OEM engine.
Old Sep 15, 2013 | 08:55 PM
One more Question
I run 340 tread wear tires on a daily basis and DR when I go goof around. You get use to the power quite easily. You can easily drive around any amount of power as long as it idles and doesn't overheat.
12 sec car is not that fast IMHO. People run that stock with today's cars.
Old Sep 15, 2013 | 09:08 PM
I would rather drive a cady during the week to work than changing tires whenever spud.... and if u cant spin the **** out of street tires (and whats the point) your not @12 sec flat boy.
Old Sep 16, 2013 | 09:51 AM
dr_whigham's Avatar
The Scammer Hammer
LS1 - 346 Ci
42lb injectors
228R
85mm MAF/CAI
SLP UDP
Damn impressive numbers for given setup. Those PRC's are stout.
Old Sep 16, 2013 | 01:09 PM
CaliboyTA's Avatar
I used to daily drive my torquer 2 (232/234 .595/.598 112) that had over 60k miles on this setup and I have no problems
