best street cam for ls1
Old Sep 22, 2013 | 03:19 PM
Decadence75's Avatar
Originally Posted by PREDATOR-Z
What work did you do to your tranny?
Line pressure, WOT Shift speed, Part throttle shift speeds, lock up/unlock speeds, disabled misfire detection, ect....
No mechanical work, just tune modification.
Old Sep 22, 2013 | 04:07 PM
perfect.ta's Avatar
Ms4 114lsa is my choice . I have it on a 99 camaro with full bolts on 42ib injectores . Borla cat back. Tuned in with shitty fuel via efi live software. Car made 400 whp and drives great . Am enjoying it . Every time I pass 5th gear . I pass with 2 foots flame from my left exhaust . And spreds to all 4 tips while I let go of the gas....
Old Sep 22, 2013 | 05:07 PM
PREDATOR-Z's Avatar
That is probably the issue you're experiencing with the SS4000, your tranny maybe slipping due to the increased torque multiplication.
Do you have a tranny cooler on it?
Old Sep 22, 2013 | 05:19 PM
Yes. A Hayden 679 not in loop with the radiator. I tapped the pan and put a sensor in and under normal circumstances it runs about 130-135*F.
Old Sep 22, 2013 | 05:47 PM
PREDATOR-Z's Avatar
Hmmm, because even with a stock cam performance is enhanced with that converter. I ran my SS3600 on my stockish LS2 before I went deep into it and I experienced better than stock stall response.
Old Sep 22, 2013 | 05:52 PM
Don't get me wrong, if I get on it, it will move. But in normal traffic, it is a dog. I thought upgrading the cam would fix the problem. I was looking at the LS2 profile of the Tick SNS stage 2 for it.
Old Sep 22, 2013 | 06:59 PM
kinglt-1's Avatar
Upgrading the cam will not help that problem...adding more gear will. Look into a set of 3.73's. I have a FTI3800 with 3.73's and the driveability is awsome. It takes about 500more rpm down low to get the same acceleration as the stock converter, not bad at all. 2000rpm accelerates like 1500rpm compared to the stock converter.
Old Sep 22, 2013 | 09:08 PM
RQSGTO's Avatar
Edc 220/224 111
