LS6 vs BBK vs typhoon
Old Sep 24, 2013 | 09:35 PM
wildcamaro's Avatar
Same dyno? Same weather conditions? All other mods constant?
Possum Boggs's Avatar
exact dyno
Old Sep 24, 2013 | 10:09 PM
Cajun ELESS-ONE's Avatar
if your going spray later on the aluminum might be better incase you have a nos backfire. if you have a ls6 or other composite intake the backfire could crack it. i was reading on heat soak and its said that the air moves too fast for the heat to affect the intake air temp.
Old Sep 24, 2013 | 10:29 PM
i just bought a typhoon85 mm off a guy on here tonight,im going to get it bolted up in a weeks or two and post pics and info on how it does
Old Sep 25, 2013 | 12:27 AM
chevybayboy's Avatar
A member on here did a comparison on the Ls6 bbk and fast 92 I'm running the bbk if you plan on spraying get the bbk that heat soak **** is B's with the bbk my intake hardly gets hot , but I believe the fast was 412 bbk was 406 and Ls6 was 396
Old Sep 25, 2013 | 09:12 AM
i opted with the 85 mm typhoon,couldnt find a deal on anything else
Old Sep 25, 2013 | 11:35 AM
MT0911's Avatar
No worries bro - it'll get the job done just fine! That intake is solid. Good luck man
Old Sep 25, 2013 | 11:36 AM
thanks alot,anything is better than stock lol
Old Sep 25, 2013 | 04:28 PM
That's cool good luck man
Old Sep 25, 2013 | 05:23 PM
chevybayboy i see you have a under drive pulley listed in your sig,could u feel any gains with it
Old Sep 26, 2013 | 10:31 AM
do you guys know if stock fuel rails can be used on the Typhoon,or what other aftermarket ones will work,mine didnt come with any
Old Sep 26, 2013 | 11:20 AM
  #32
To be honest I couldn't tell you I did slot of stuff when I changed the UD
Old Sep 26, 2013 | 04:49 PM
  #33
whats gaskets are u running
Old Sep 26, 2013 | 08:57 PM
  #34
mgood613's Avatar
I bought the Pro Comp version of the Typhoon. I thought I was getting a deal until I realized I had to by an after market fuel rail set up.
I have a 1999 Camaro Z28 LS1, I had BBK Long Tube Headers, cat delete, borla cat back, slp lid, 85mm throttle body, 85mm procomp intake, stock 853 heads, and the GM ASA cam. It dyno'd 341hp 332ft lbs.
5 months later I have installed a ls6 intake, PRC stage 1 heads milled .030, and had it re dyno'd. 432hp and 393ft lbs.
Same dyno, same tuner. The first thing he said when I showed up the first time was, Get rid of that intake!!
Just my experience on this style intake.
Old Sep 26, 2013 | 10:00 PM
  #35
man ive heard the same stories with both intakes lol i just dont get it lol
Old Sep 26, 2013 | 10:01 PM
  #36
i mean ive heard guys say the ls6 was the way to go and guys saying the typhoon made more power,just seems like every car and set up reacts differently
Old Sep 26, 2013 | 10:08 PM
  #37
mgood613's Avatar
Just giving my experience. I looked here before I bought mine and said the same thing you just told me. I even measured the port differences and said how can smaller ports produce more hp, but it did. Big Time!!
Old Sep 26, 2013 | 10:09 PM
  #38
do you have any track times with your set up now?
Old Sep 26, 2013 | 10:13 PM
  #39
mgood613's Avatar
With the old set-up it I ran a best time of 12.7 at 113hp. This is with street tires and a m6 with 3.42 gears. 2.2 60ft
I am trying to get to the track Oct 6th with the new set-up
Old Sep 26, 2013 | 10:17 PM
  #40
keep me posted on times,did you have any trouble with your typhoon as far as the install or anything,sorry for the 100 questions,im just on a budget lol
