383 with 806 heads question
I'm looking into buying a set of 806 heads that have been port and polished. Flow sheet show they are a little better than a set of prc 2.5 heads. My only question is does anyone know if I will need short pushrods with these heads. Any info will be appricatated, thanks.
Have to put it together to find out.
Depends on if the heads have been milled.
Depends on the base circle of the cam.
Depends if the block has been milled.
To many factors to make a guess.
