cam base circle/pushrod length ?s HELP!
Old Sep 29, 2013 | 09:34 PM
crainholio's Avatar
Originally Posted by X-Bomb Racing
You're checking where your rocker is riding on the tip of the valve and adjusting the push rod to make it ride closest to the center while you rotate the motor aren't you? Just making sure your doing it right.
For an LS engine that has fixed-height pedestal rockers, that advice is as f#cked up as a football bat.
Old Sep 29, 2013 | 09:46 PM
crainholio's Avatar
Originally Posted by allan808
What i did was, on #1 cylinder tdc, i watched as the intake got to full open then measured the exh side. Then turned the engine till exh was full open then measured the intake! is that correct?
The method you used ensures the lifter you're measuring is on the base circle, so your measurements will be accurate assuming you're using the pushrod tool correctly.
Ignore the other guy's post about rocker tip contact pattern on the valvestem surface...not applicable to pedestal rockers unless you've changed valves and/or rockers.
This geometry applies to stud-mounted rockers where the rocker height is a variable that has to be accounted for in the pushrod length. Not the case w/ an LS engine running stock rockers or other pedestal-mount pieces.
Old Sep 29, 2013 | 11:50 PM
allan808's Avatar
Yes i do know how to use the tool, every full turn is 50.right? lol.. ive tryed three different length pushrods! and measured 2 different ways!
The first was the eo/ic meathod wich cam out to this.
7.400 pr. int 1.6 turns exh 13/4 turns to 22lbs
7.375 pr. Int 1.35 turns exh 1.45 tuns to 22lbs
The second measurement i did was found 0 lash by slowly turning the tool and taking on and off the rocker till i could tighten the bolt snug and have 0 lash without pushing the plunger. This is what i came out with.
Pushrod length. 7.270+/- without preload. Added .80 for preload to get 7.350 pr. I then put rocker on and turned the bolt to 0 lash, then counted 1 turn to 22lbs.
the 2nd measurement confuses me.
A little info on the engine, ls3 with .40 mls gaskets. Heads have been cnced & valve job. Intake valve sits in .14 and exh .11, im pretty sure he cut the valve tips to factory height.
Old Sep 30, 2013 | 12:27 PM
allan808's Avatar
Also the heads are not milled.
Old Sep 30, 2013 | 08:33 PM
allan808's Avatar
And im useing stock rockers & ls7 lifters.
Old Sep 30, 2013 | 08:39 PM
X-Bomb Racing's Avatar
Thanks for the advise. I am very new to the ls and i came from the old school sbc. I assumed it worked like a sbc does. The only point in measuring push rods in a sbc is to get them to ride and push down in the center of the valve stem.
I'm about to go through this myself here shortly and i have a feeling im gonna be learning something new..lol OP scratch what i was saying
Old Oct 1, 2013 | 03:35 PM
allan808's Avatar
Im in the same boat, my first ls!
Old Oct 1, 2013 | 03:41 PM
Virgins lol
Old Oct 1, 2013 | 05:50 PM
crainholio's Avatar
If you do a search on "LS7 lifter preload" you should find a long thread that has good info for you in helping select the right pushrod length based on your measurements.
Old Oct 1, 2013 | 06:07 PM
allan808's Avatar
Virgins lol
Lol, ls is a lil different.
Old Oct 1, 2013 | 07:29 PM
allan808's Avatar
Ok so this is where im at! eo/ic method @7.375 pushrod i get right below 1 1/2 turns to 22lbs.
Now when i measure just to 0 lash i get 7.270+/- then add in .75 of preload i get a pushrod length of 7.350. this is whats confusing me! what one should i go with?
Old Oct 1, 2013 | 07:33 PM
  #32
td1168's Avatar
That's the funniest thing I've read on this forum since becoming a member! Football bat!
