No Oil Pressure - Faulty Pump?
I am doing a conversion in an old ford F100 and just came to the point of first start. We replaced the oil pump along with swapping the pan (OEM pump H3 pan). I assumed it was the pickup o-ring as usual, but it did not show any signs of damage when pulled.(red coated type so easy to see if pinched).
I went ahead pulled the pump apart. It was completely dry and there were some aluminum shaving along with these marks on the housing and rotors. There is groove I can feel with my fingernail in the middle of the surface along with a wider one closer to the outer circumference. I assume this is not normal, but was curious if you guys thought it was cause zero oil pressure and a dry pump?
Another note. This was a replacement pump after the first one from scoggin dickey had a cracked housing. I worry that for whatever reason there was a bad batch from their manufacturer. Even this one has a some impact marks on the housing along with a question mark inscribed with sharpie.
I was not around for the initial installation so it is possible it was not centered properly.
Should I just go ahead and grab another pump?
