Issue with arp harmonic balancer bolt help help
Old Sep 30, 2013 | 10:35 AM
baldeagle432's Avatar
Default Issue with arp harmonic balancer bolt help help
Ok guys i was tring to install my harmonic balancer on the 5.3 in my rx7 yesterday and the first three threads got fucked up. i ran a tap down the crank and its fine but no one has a damn arp bolt that i can get in the next day or two its on back order so i was wondering if i can just cut off the messed up threads and use the rest of the bolt its still very long what do u guys think i just need it to last for a week or two will i can get a new one i have a photoshoot for it this weekend for a magazine need to get it up bronto
Old Sep 30, 2013 | 11:22 AM
conan's Avatar
Can you get a OEM bolt from a dealer or a auto parts store. Or go to a hardware store and get a 10.9 grade bolt and torque it down to arp specs.
Old Sep 30, 2013 | 11:31 AM
ROCNDAV's Avatar
Can you find a hardware store that carries a metric nut of the same size that you can run up and down the ARP bolt? Where did you find the tap? DO they also carry the same size die that you can you to clean up the bolt's threads ?
Also, It helps to find threaded rod and nuts to pull the balancer on. Once you get it on good enough you can remove it and use install the crank bolt.
Old Sep 30, 2013 | 12:26 PM
01ssreda4's Avatar
Don't matter you're just gonna screw the crank up again. You never mentioned how you plan on actually installing it correctly this time. You don't honestly think damaged threads are going to hold do you?
And the fact that you think that after 3 threads failed to engage, cutting the bolt shorter will somehow make this work out ok.
Old Sep 30, 2013 | 04:27 PM
wildcamaro's Avatar
You're gonna need a helicoil...a big one
Old Sep 30, 2013 | 04:34 PM
ROCNDAV's Avatar
OP, where are you located?
Old Sep 30, 2013 | 04:56 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You may need to repair the threads but we have the ARP and gm bolts in stock
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 30, 2013 | 05:45 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Please confirm something: Did you screw up the threads
-on the ARP bolt?
OR
-in the crank?
Old Sep 30, 2013 | 06:29 PM
wildcamaro's Avatar
Sounds like both!
Old Oct 1, 2013 | 03:41 AM
vettenuts's Avatar
Yep, if you pull it on with the ARP bolt the same thing will happen. How is this being installed? Sounds like the correct procedures are not being followed and the crank is suffering as a result.
Old Oct 1, 2013 | 06:02 AM
Old Geezer's Avatar
Read what the OP stated in the beginning of the thread....
" i ran a tap down the crank and its fine ".
Old Oct 1, 2013 | 06:55 AM
Paul Bell's Avatar
Yessir, I did see that. I'm trying to determine if he damaged the crank threads THEN ran the tap through them and now they're fine.
If he damaged the bolt only, he's still in good shape but I'd think if the bolt threads were damaged, so were the crank threads.
Old Oct 1, 2013 | 08:29 AM
badazz81z28's Avatar
Oh Brother....Read between the lines....The OP just wants to know where to get a new bolt...
Summit Racing....Jegs....Autopart Store...
I have a speed shop that keeps them in stock.
Old Oct 1, 2013 | 08:45 AM
96lt4c4's Avatar
Home made balancer install tool from old bolt.
Old Oct 1, 2013 | 12:23 PM
01ssreda4's Avatar
Yep, that's the dumbest thing I read all day. If you strip the threads, the tap doesn't magically put them back. To the other guy that suggest he "just needs a bolt", well when he gets his hands on one, he is gonna try the same procedure again.........
Old Oct 1, 2013 | 12:34 PM
ROCNDAV's Avatar
Don't hammer the crank pulley on. Get some threaded rod.
Old Oct 1, 2013 | 06:23 PM
Paul Bell's Avatar
Yeah, we all know that. Most of us also know that if he's screwed up the bolt threads, he's probably also screwed up the crank thread.
We're all just trying to prevent him from doing any more damage.
It'd be great if he stepped back in here to update us-or respond to our posts.
Old Oct 1, 2013 | 07:19 PM
wildcamaro's Avatar
Gonna need a helicoil or a new crank bottom line, I would run an engine with even one damaged thread, that's the **** wrench thing to do
Old May 22, 2020 | 02:30 PM
Ssgmatt's Avatar
Why would he step back in? He asked a question and can he cut the three damaged threads off and still use the bolt not would you pull the crank out and start over or do you have a damaged thread on your motor geeez. The answer is obviously we don't know. Call Grainger or Fastenal find out tensile strength see what they think, or you could try arp although I'm sure they will say no to avoid the fall out if something did happen and they want to sell you. Personally if your still getting around 75% of the total threads you had before and it torques to 235ft/lbs I would run it. Bolt just presses the pulley on and holds it just check it when you stop the first few times mark it see it it moved my opinion. And I don't want to come inspect your work lolhlol you never know the person your talking down to might be smarter than you obviously you were smart to enough to know to ask for help. Good luck.
Old May 22, 2020 | 02:46 PM
Paul Bell's Avatar
Ssgmatt, welcome to LS1tech!
You've replied to a thread that's seven years old. I'm certain the OP has this fixed.
