Anyone know where I can find OBD II Mode 6 TID & CID definitions?
This is for my 2001 LS1 Corvette.
These are the raw data for things like Cylinder miss fire counts, etc. The data is in hexadecimal format so you have to know which one corresponds to the parameter you are looking for.
Generally the PCM will not throw a code until a threshold is met. As an example, you could be having a miss fire under certain conditions but it won't show up as a code because the miss fire count is below the threshold.
