Cam Help ( Cam Guru's Please Come On In )
HKE 383 11.5:1 CR
Ported 243's
Ported fast 90
Th-350
Neal chance stall 4800
4.30's
Here is a video of it in action
Thanks for contributing to the thread(and Martin).you guys are 2 of only a handful of people on this board who are qualified to give advise on cams,the lesson and advise is very appreciated.
That said, even with that information and feedback he was still weary and wanted to make sure he spent his money wisely. Which is why I'm sure he made this thread. I don't blame him at all.
I'm sure Brian feels the same as I do that we are able to grind some of the best cams in the LS industry with the knowledge that we have. This comes from testing, lots of data and customer feed back including doing things on your own. I know I plan to test many cams in my new turbo engine in my radial car.
When it comes down to it, if you have seen great results from a certain cam grinder, including your own friends, trust them and leave the decision in their hands. That said, provide your cam grinder with as much information as possible so he can make a calculated decision on what camshaft is best for your application.
Thank You and Brian very much for your useful insite, it now has allowed me to narrow down the choice.
Even with the information in front of you it can still be very confusing.
If you have any more questions please don't hesitate to contact me by email or phone.
Car is a 2001 SS that I am currently building a Iron Block 408. Compression is upwards of 11.5 to one.
Intake- Will either be one of the following Fast 90 with a NW 90 ( I already have this one, trying to sell it though ) or a Ported Fast 102 matched to my new heads.
Heads- are CNC ported TFS 235's with a little work done to them.
All forged bottom end, so it should hold up.
Trans- is a 4160E, with a Yank 3600,rear gear will be 3:73.
Exhaust- Will be TSP 1 7/8" SS with a 3" ORY connected to a Magnaflow Catback.
My car is not a daily driver so driving it everyday is not an issue. With that said I am looking for a good all around street car, that will make great power, be valve train freindly, and fun to drive. I have heard that the 408 will have good torque. This car will not be a weekend drag strip warrior, however I may take it to the strip every now and then, and or compete in a little local street racing. Not planning on any juice, ( at the moment ).
I have spoken with ( 3 ) guys and below are their recomendation's concerning camshafts. I was wanting to see what the Tech community thought about them good and or bad. I was told that the higher duration would deliver more all out power numbers but suffer some low end torque, and the lower duration would deliver more all out torque but suffer some power numbers.
1. 243/250 .624"/.615" 112+5 Recomended by a Tech sponser ( no names mentioned ) dont know what the lobe design is it's supposibly a custom cam. Pros/Cons
2. 239/250 .621"/.595" 113+2 Recomended by a Tech sponser ( no names mentioned ) dont know what the lobe design is it's supposibly a custom cam. Pros/Cons
3. 232/238 .625"/.625" 113+4 or 113+4 Recomended by the guy that is completing my short block assembly. dont know what the lobe design is it's supposibly a custom cam. Pros/Cons
4. 235/242 Lift .620/.610 113.0 +2 Lsr on the intake, and a Lxl on the exhaust, Already Have this one new in the box. but was told that this lobe design is a little on the ragged edge. Pros/Cons
Any and all help would be greatly appreciated as it is getting time for me to pull the trigger on the new cam, as the shortblock is almost ready for assembly.
You are no cam grinder, you are no engine builder.
I hope they ban you soon.
Don't edit your post now either. Don't flatter yourself and try to make yourself look better by saying I've stolen stuff from you because you have nothing to steal from!
Show me 5 cams you have designed. Track results, dyno sheets and customers who can come on this board and give a review of your camshafts.
I will never post on this board again and cancel my account if you do so.
I'm also 25.
I will never post on this board again and cancel my account.
Funny how you flame me and call me a kid, when you don't even know how old I am, yet you ignore me asking you for proof that you've ever even ground one camshaft let alone five.
My point is proven.
I've learned to ignore every other troll on this forum, but something about you, you just **** me off, and I'm going to be a bit brash I has have not been in a while as I've learned not to play into these games. None the less here we go.
I've kindly asked you to prove me wrong, didn't call you names, didn't personally insult you in any way.
I asked you to show proof that I am wrong.
Yet you cannot even do this.
Instead, you divert to name calling, degradation, and calling me a kid.
Let alone you stoop so far as the last ditch attempt to save some kind of face, you say that I've stolen YOUR work?
BWAHAHAHAHAHAHAHAHAHAHAHAHHAHAH
That's the best one I've heard in a long, long time.
Tell me Bozz Hawg(since you hide behind a screen name while I post with my full name shown) what did I steal from you?
Cam- 232/238 112+2.
Been trying tons of Cams through the years and I always fall back to the smaller Cams for power across the curve. Valve events can put you in the ball park but without testing there is no perfect answer. I've run cams that should not work going by valve events but they end up working very well.
Bozz hawg, you can thump your chest all you like. You may be good, but it seems you can't prove it.
Martin, he ain't worth it. Glad this has resulted in some great knowledge drops, at least.
If you never owned LS3 or L92 heads, how and why were you specing cams for a head you never had any experience with? So you were interms, just guessing at the expense of someone else.
I have been daily driving them for about 4 years now and have tried several combinations with my car, customers cars, etc..... Lets look at the 821 verification in my photo.
This is important because I always talk about guys who talk about parts but never owned them or used them.
You never owned a square port head Ls3,L92 or LS7 so how could you recommend a camshaft to a customer that you never used? Unless you parrot or copy someone elses information?
Can you answer that for me please? No name calling.
I don't talk about or reccomend parts I have never used. Maybe you should do the same.
Does that mean they aren't qualified?
Your problem is your mentality. This isn't a ring, this isn't a battle, this isn't an argument.
I asked you to prove me wrong. You cannot deny the results I get whether on a dyno our on a track.
You have berated me for over a year. Calling me names and taunting me.
Did you miss where I said the car I posted the results from ran the same et he did on 100 less jet with my cam?
I asked you kindly and you resorted to name calling.
I respect you grinding your own camshafts, but enough with the smoke and mirrors regarding privacy.
You don't even have to give me specs, just 5 reviewers of their own accord on their own accounts acknowledging you grind their cams and that the "theory" behind your cams disputes what I've said to be true.
I also asked you to share what I've ever stolen from you because all your theory is polar opposite from mine. How is that so if I stole your work?
I would appreciate a civil response.
This thread is about cathedral port cams yet you've gone off talking about square ports as always.
I own a 370 with lsa heads btw.
I didn't ask for you to post. I asked for 5 customer reviews along with your analysis as to why a later Evo is beneficial.
Not to post pictures of your cams in your daily driver you took today.
