408lsx help!
Old Oct 3, 2013 | 10:20 PM
LSjim's Avatar
Default 408lsx help!
I have a lq4 bored and strokes to a 408. I'm using wiseco pistons and eagle rods and Callie crank. The rings are gapped for boost but am not sure the exact gap . The problem is I'm buring a ton of oil I am running vr1 20-50w oil . I have driven it about 60 miles it has a lot of blue smoke coming out of the exhaust at idle and under heavy throttle in the beginning but clears up. Any help would be appreciated
Old Oct 3, 2013 | 10:55 PM
LSjim's Avatar
No I had a engine builder do the short block
Old Oct 3, 2013 | 11:01 PM
LSjim's Avatar
I have stock 243 heads with light porting I am thinking maybe they put the wrong valve seals ?
Old Oct 4, 2013 | 04:15 PM
LSjim's Avatar
all 8 spark plugs drenched in oil
Old Oct 4, 2013 | 05:06 PM
01 Vert ws6's Avatar
Did you use break in oil , isn't the vr 20/50 synthetic oil , you should use regular oil to break in the rings then after 1000 miles change the oil and filter
Old Oct 5, 2013 | 01:13 AM
LSjim's Avatar
Well on initial start up I used Joe Gibbs br30 and no there is vr1 senthetic and non
Old Oct 5, 2013 | 02:18 AM
Raven02TA's Avatar
check to make sure the valve seals arent damaged or are missing their spings.
Old Oct 5, 2013 | 03:58 PM
OUTLAWZ RACING's Avatar
Sounds like seals are not seated. Also you should use thread sealer on the rocker bolts. The hole is not blind you can see it over the intake valve. Hows your pcv system?
 Michael S. Palmer
Old Oct 6, 2013 | 01:38 PM
Burken01's Avatar
Rings are already set, they will seat up after 5 minutes..
But yeah drive it like you stole it
Old Oct 6, 2013 | 04:22 PM
A.R. Shale Targa's Avatar
Could be lots of things...valve guides shot; improper hone finish for the rings
used; way too wide of gaps; rings upside down;....generally speaking low
tension piston rings control oil better that is thinner like 5W30
Old Oct 30, 2013 | 09:27 AM
LSjim's Avatar
Sorry been really busy just turned out the Pcv system was messed up I had the fresh air port going straight to the intake manifold scence I fixed it I put over 100 miles and no smoke
