Misfire help
Old Oct 8, 2013 | 03:16 PM
icetea07's Avatar
Default Misfire help
I have a 99 z28 Camaro. There is over 150xxx miles on the car. I have a bad misfire on cylinder 2. So I pulled the plug to check it there was a little oil on the plug. What could cause this?
Also it has been using oil.
Old Oct 8, 2013 | 03:41 PM
RockinWs6's Avatar
You need to do some more testing, compression test, leak down, spark, fuel injector.
