Build plans. Tell me what u think or if in missing something!
Plan is to build this for my 95.
Car is a weekend warrior only. Stripped down pretty decent.
2006 lq4 short block
Hand ported 799s (unmilled)
Ls6 intake
Stock ported tb
Tick performance Sns torque max stage 3 kit
.41 head gasket
Ford green injectors
Long tubes
Either y pipe/muffler dump OR lm1 stright to the headers
T56
410 gears
Monster stage 2 clutch/flywheel
Tick master
What's your guess on power? Anything I'm missing that I should do while I'm there? This is a slow moving project but the chassis should be ready for the motor in a few weeks (as soon as I get to working in it again)
Thanks for your opinions!
Ls6 intake
Stock ported tb
.41 head gasket
Long tubes
T56
410 gears
Tick master
I ran a 238/242 cam in my 346 and when I pulled the heads to port them there were marks on every piston from where the valves just kissed the pistons a few times...I got very lucky and didn't break or bend anything...measure measure measure
O ya I plan to check it and make sure. Martin at tick sounded pretty confident it would clear no problems so that gives me hope lol. Never hurts to check to be sure tho, cuz I'm not planning on a bottom end build any time soon!
Well bought a stock 2000 z28 so the plan is to put this motor in it now but instead of a using a t56 keeping the car auto with a yank ss3600. Should make for a good winter project.
What's the best way to check ptv clearances?
I got very lucky on ny stock cube motor. I pulled the heads to port them and had marks on every piston where the valves touched but didnt bend with a 238/242
Super Hulk Smash
Everyone knows .080" is the minimum recommended spec. But from what I've seen or heard, .060" is safe as you usually don't make contact. Once you get to .050" you start to make light contact once in a while as evidenced when you look at the pistons. Then .040" leaves marks more visibly. Anything tighter than that and you're really playing with fire.
I'd feel comfortable at .060" but not much closer.
Are you adding the depth of the dish to your valve drop measurements? From the looks of those calculations you were not.
Just taking into account radial clearance and depth, you'd have roughly .030-.035 added clearance with the LQ4 pistons.
How does the dish 'radius' of the lq4 pistons and the radius of the valves match? I guess what I'm asking is because I think by looking at pictures of people te fly cut the stock lq4 pistons it looks like even tho there is a dish the 'flat top' part of the pistons around the piston could still cause issue? I don't know how/if that has an affect on anything.
Martin at tick has been extremely helpful on more then one occasion. Thanks for the info!!!
Martin, so I'm not sure how to do the math lol but I think that means in theory ill have .071 clearance? Is that using .041 gasket? Should be plenty?
Would a sns stage 2 offer better clearance with out a major loss in power? I'm really wanting a good max output. I just hate to buy the stage 3 and it not fit. I don't want to fly cut the pistons since ill be spraying it as well.
What's guess on power going through an auto?
I'm really dragging this out but I don't want to make the wrong choice lol.
